Have to take the cover of the unit and observe the vcr rejecting the tape action. If it is the take up wheel not working; you might keep the unit on vcr for a few weeks. this will dry up the circuit from condensation and take up wheel will work again?
you posted 2 different problems here... to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Hi dear look like loding gayr broken if it is then u can't do much about it even theu u figure out the gaier brokin .ok cheack the gair under the mechnisem or right hand site all vcr gair have timing set up with a mod swtich every gair have mark on it or holin it .they have to match ....if dont find any brokin gaier so find the mode switch trry to clean that some time they get old & contcat not good any mor function error (make sure the timing of gayer very important mark evry step u do so u can put back to gather )good luk
