SanDisk Sansa Fuse  MP3 Player Logo
A
Anonymous Posted on Dec 02, 2011
My sansa SanDisk 4gb player locked up and won't do anything
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • SanDisk Master 102,366 Answers
  • Posted on Dec 28, 2011
SanDisk Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441756
Points
622693
Slide the power switch up all the way and hold it there for fifteen seconds or so. This will reset the player.
If this doesn't, please reply to this post and we can go from there.
2helpful
2answers
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
Won't turn on
Please give some more details.
I suppose it's the problem that your Sansa e250 MP3 Player won't turn on.
You could turn to Sansa official support.
My sansa clip is frozen on the blue flower
One issue that people experience with the Sansa Fuze player is that the screen turns white when they are trying to use it. If you experience this common Sansa Fuze MP3 player repair issue, you need to reset your player. Hold down the "Play" and "Power" buttons for about 20 seconds. The player should automatically reset.
MP3 Player Freezes
Another issue is that the player freezes. You may see lights on the player, but it won't do anything. Follow the below steps to correct this issue:
1. Use the above steps to perform a hard reset.
2. Turn the player back on, and slide the "Power" button upward.
3. Use the USB cord that came with your player, and connect it to your computer. Only connect your player directly to the computer. Don't connect it to a USB hub.
4. See if your computer recognizes that a device was connected to it. Or, look in "Devices and Printers" folder, and see if the device shows up in it.
If your device doesn't reset, and the computer doesn't recognize it, contact SanDisk for additional assistance. Or, you can attempt to repair the device yourself.
Repairing Internal Components
If your Sansa Fuze player is out of warranty, you can attempt to repair internal components. This is an "enter at your own risk" solution, but you may be able to fix the issue. If it doesn't work, or if you damage another component, you will most likely need to get a new player.
1. Shut off the device.
2. If you don't have one, purchase a case opener tool. This is a tool with an extremely small head that is used specifically for opening up small devices.
3. Place the head of the tool in the seam of the device, and rise up the faceplate. Do not do this forcibly, or you'll break the ribbon cable connected to it.
4. Remove the ribbon cable from the faceplate.
5. Examine the battery cable. If this connection is loose, your Fuze player won't turn on. Plug the connection firmly into the port.
6. Check the LCD screen connection. A loose connection here means that you can't see anything on your screen. Disconnect the cable from the port, and reconnect it.
7. Reattach the cable to the faceplate, and reattach the faceplate. Turn the device back on.
These Sansa Fuze MP3 player repair suggestions may not fix all issues. If your player is still not working properly, either take it back to the place where you bought it, or contact SanDisk for additional help.
References
Fixya.com, http://www.fixya.com/support/t4267400-sandisk_fuze_4gb_locked_lights_will_not
SanDisk, http://www.sandisk.com/products/sansa-music-and-video-players/sandisk-sansa-fuze
Unit wont turn on??? was charging unit overnight,now wont turn on tried holding all buttons for 15,30 seconds
It sounds like it's time for a new battery. Here is your battery:
http://cgi.ebay.com/550mAh-Battery-SanDisk-Sansa-Fuze-2GB-4GB-8GB-/200582416758
If replacing the battery doesn't get this player up and running, you will need to contact Sandisk for repair or replacement of your player.
  • Website: http://www.sandisk.com/consumer-products/
  • Address: 601 McCarthy Boulevard, Milpitas, CA. 95035
  • Phone: 1-866-726-3475
  • Email: [email protected]
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SanDisk 4GB MicroSD HC Memory Card is not recognized by my Sansa
sd utility.exe u download from google it wil dolve u r problem.......
Sansa e260
The e260 works with microSD cards. Your 4GB card is actually a microSDHC card and won't work in the Sansa.
With a microSD card, simply put music tracks into a folder called "MUSIC". When the card is installed, the Sansa will see the additional tracks.
2answers
Sandisk Sansa e260 4GB Media Player manual
http://www.sandisk.com/sansa/#/support-0/
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
