Question about Panasonic Viera TH-42PZ80U Plasma TV
I have a Panasonic plasma hdtv. When I try to power on, usually I just get the red light to flash--continually. Sometimes I can keep pushing the button and the tv will power on, but usually just the continuous flashing light. Can anyone help?
Posted by randall sparks on
Rocky
    Sergeant:
  • 302 Answers
Hi that sounds like your power supply is defective. The flashing light is actually a code that you can look up in the service manual. Depending on the number of times it flashes. If yo are going to order the part yourself you have to actually get the part number from the actual part. Don't order it just by the model number of the TV because manufactures make a few different versions of the same model TV.
You can get parts at www.interliquidparts.com
Posted on Dec 02, 2011
Who to fix broken panasonic plasma tv
Adam, 1 st thing to try is holding the power button in 20 seconds and see if it resets.Check the links below and do not be afraid to google search your problem yourself, there is a lot of info. out there onm this problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Panasonic Plasma TV Repair Understanding 10 Blink Code for 2011 Panasonic...
Panasonic 10 flashing red light
Panasonic Plasma 10 and 2 Blinks TEA1611 ETX2MM702 704 706 Power Supply TH...
May 02, 2016 | Panasonic TCP65VT25 65 inch VT25 1080p...
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Red led power light comes on and flashes 10x. TV will not turn on. What is the problem
Its a error code and usually indicates power supply or something loading that down.
Dec 12, 2012 | Panasonic VIERA TC-P42G25 42-Inch 1080p...
Panasonic th-50pz800u shuts down and i can not turn back on, red light flashing 2 times, sometimes 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 20, 2012 | Panasonic Viera TH-50PZ800U Plasma TV
I have a panasonic plasma hdtv. When I turn it on--usually--the red light flashes. It flashes continually--not in a sequence. I can keep pusing the power button and sometimes the tv will power on--but...
Must have to take the tv aparts,check the tv power supply board carefully.That the board where the tv a/c power cord plug into it.Look for dying and leakages capacitors components parts.These dying and leakages capacitors parts are causes this problems 90-95% of the times.These dying and leakages capacitors components parts are alway bulges up and or puffing up onto it tops.It dosen't supose to have a flat tops as those are good capacitors components parts that are alway have flats and even cyclinder head tops.If u have all the tools and know basic electronic and also u can do basic soldering work too than u must have to changes all these dying and leakages capacitors components parts that are bulges ups or puffing ups on to it cyclinders tops,will solved this tv problems LED power liight inconsistance staying on power LED light indicaton flashes.If u can't do soldering works on an a electronic board components levels works.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Dec 02, 2011 | Panasonic Televison & Video
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Panasonic Viera TH-42PZ80U Plasma TV Logo
91 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
