Question about Linksys Wireless-G Broadband Router
Cant connect my kindle to wi fi router
I know my password but i cant connect my kindle
Posted by lesley smith on
Scott Fryer
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
My monther's issue was because her ISP's (Bell) router, home hub 3000, comes default with the 2.4G and 5G SSID named the same with the same password. So her 2.4G was on a Band that was super weak, like 30%, but her 5G was at 90%. This was causing her wifi connections to use 5G as it was more available. Problem with the kindle is that it is limited to use the 1 - 11 channels / 2.4G only. I resolved this by going to the routers config (192.168.2.1) and changing the SSID from Bell553 to Foxtrot. Then i changed the 5G SSID to Foxtrox-5G and made different passwords for both. Rebooted the router and the kindle was able to connect to the 2.4G network.
Posted on Jan 09, 2017
robert w
  • 550 Answers
Check the wireless settings of your router and then try to connect Kindle to the wireless network . If your wireless network is secured then make sure that you are typing the correct network key.
Posted on Dec 05, 2011
How to get connected to wi fi
To connect to a Wi-Fi network with a hidden SSID, select Add Wi-Fi network from the settings. Then manually type in your SSID and password, and select your network security type. Select Save when finished. Now you can browse the web through your Wi-Fi router or connect to other network devices
Sep 18, 2016 | Amazon Kindle Touch Screen Wi-fi W/...
I'm having trouble connecting my new Kindle to my wi-fi
trouble connecting my new Kindle to my wi-fi Mary, Check the attached links,instruction and guides to get kindle connected, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Can Connect Kindle 5th Generation to Wi Fi
Fix Kindle HD WIFI problem EASY
kindle won connect with wi fi
12 major Kindle Fire problems and how to fix them
Aug 03, 2016 | Amazon Kindle Paperwhite
I have no idea what my Wi-Fi password is, so can't activate the Kindle. This is my 4th Kindle; I bought the others with no help, but have no record of Wi-fi password.
The wifi password is the password installed in the router that allows any and all wireless devices to connect to your wireless network. Unless this Kindle is the only wireless device you have, then you probably know the password, since it was used on all the other devices as well. Even if you don't know it, you may have it. If the router was from the ISP, and you didn't change anything, the wifi password may be written on the base of the router. If you DID change the password and forgot it, as long as you can access the router setup,. you can go in and create a new wifi password.
Jan 15, 2016 | Amazon Kindle Fire HD 6 Tablet - 16GB
My kindle cant connect to internet
Go to the Settings Menu, Select the Wireless & VPN option and see if you are in Airplane mode, if you are turn that off. Then select Wi-Fi. See if Wi-Fi is turned on. If it's not turn it on. There should be a list of available Wi-Fi routers. If one is not selected select one that is open or that you have the password to. If none are open or they are locked and you don't have a password, you'll need to get a password for one, or install your own Wi-Fi router.
Jan 13, 2016 | Amazon Kindle Fire HD
How do I connect to the kindle store my kindle will not connect so I may download kindle books?
To connect to the Kindle Store your device must have either a wi-fi connection to the Internet or a 3G Whispersynch connection via a telecom. Some Kindles come with the 3G and some don't. The ones that don't require a Wi-Fi connection.
So, if you have Wi-Fi access the turn off Airplane mode in Settings and enter the Wi-Fi password to your router. If you are using public Wi-Fi such as at McDonalds you might have to
use the experimental browser in setting to be able to click the *accept terms* button or you will not have access even if connected.
Feb 26, 2015 | Amazon Kindle Paperwhite
My kindle wi-fi keeps kicking out. I have G3 and never had to put in a specific wi-fi source. Now it continually asks me to connect, and won't even accept a proper on our home wi-fi router.
Your kindle has a sim card installed for 3G (lifetime licence paid by amazon and paid for on purchase price on the unit) but that is not related to the wi-fi function on your kindle. Your wi-fi service needs to be logged in to with the same password as you use to log any computer on to your router when at home or whatever wi-fi password is required when elsewhere (e.g a bus, train or restaurant).
Dec 05, 2014 | Amazon Kindle Model D00901 Tablet Reader...
How to tune in kindle to wi fi?
From the Home screen, press the Menu button.
Select Settings, and then select view next to Wi-Fi Settings.
In the list of detected networks, choose a network to connect to it.
If your Wi-Fi network and router support WPS (Wi-Fi Protected Setup), your Kindle will detect it.
If you don't see your network in the list, you need to add the network manually.
If the network is protected by a password or WPS (Wi-Fi Protected Setup), enter the password and then select Submit.If you don't know the Wi-Fi network password, contact the person who set up the Wi-Fi network.After you connect to a Wi-Fi network, your Kindle automatically connects to it again whenever that network is in range. If more than one network is in range, your Kindle automatically connects to the last network used.
Aug 16, 2014 | Amazon Kindle Fire HD
Cant acess my wi fi on my kindle fire as it needs my parental password which i cant rember
Not positive but think you will have to unregister the Kindle and then re-register it. You will lose everything.
Mar 09, 2014 | Amazon Kindle Fire HD
My kindle keeps asking for a wi-fi password for sky37606
If sky37606 is your own wi-fi service then the password is normally on a typed label stuck to the wi-fi router itself along with the SSID of the wi-fi network which should be sky37606 in confirmation you are connecting to the correct network.
If sky37606 is not your own wi-fi then you will either need to contact the owner or administrator of that network or select a different wi-fi network to connect to as described in the Kindle Support web pages for your device.
Dec 27, 2011 | Amazon Kindle Wireless Reading Device
Can't connect wi-fi to kindle. I don't know which password they want for Barrow
The password that your kindle is asking for is the password that the WI-FI network is encrypted with.
Apr 18, 2011 | Computers & Internet
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
