Question about Sony KP-65WV700 65" Rear Projection HDTV
Kp-65wv600 looks like I'm watching a 3D tv but not tv isnt 3D It has a blue, green and red out line behind the person could it be the lamp light and if so what color
I turned on the the tv heard a pop and then the colors went crazy. I think it is one of the lamps but not sure or what color it would be. everything is in a tunnel. outline with 2 forms of colors.
    Sergeant:
  • 299 Answers
Hello sburdano,
Welcome, and thank you for using FixYa!
To answer your question: The colors are all working, they are just out of alignment.
Judging by what you have said hear, I would assume that the television have been moved, rather roughly, or bumped into rather abruptly. The color wheel will need to be re-aligned to the lamp and lens. You need to find out what your local TV Repair shop would charge for re-tuning.
Have a great day!
Posted on Dec 02, 2011
6ya staff
SOURCE:
Heard a loup pop when I turned the tv on; the timer/lamp/standby/temp lights on the power on button are now flashing; when I pushed the power button again the lamp light on the power button flashes and...
Color Wheel - Pull out the Lamp using a flash light look right into where Lamp was you should see the color wheel turn TV on watch to see if wheel is turning,From what you have said Problem will be the Color Wheel. Encompass Parts Distribution has them 1-800-638-3328
Sep 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
HL-R5667W Picture just went blank, no sound. turn on tv the timer,lamp and stand by/temp light all flash. replaced lamp still same issue heard intermittent whirling fan rubbing sound before it went bad
Sounds that tv got color wheel problem that will be replaced.
If you are handy with electronics stuff repair then replace color wheel in light engine of tv to solve its issue.
Sep 13, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Tv went grayscreen, flickering. turned off, then
When you had gray screen and flickering you had only one problem - color wheel. After "putting everything together" you have totally different problem, caused by multiple possibilities like: forgotten connectors, cut/jammed cables/wires, lamp not being inserted properly, lamp door not being set properly, disconnected color wheel, etc. Try to open rear cover and redo what you have done. Remove optical block, check everything visually and slowly put everything back. If still no luck - then only skilled TV repairman may (or may not) help.
Mar 10, 2010 | Samsung Televison & Video
Samsung TV made a big ''POP''
replace the color wheel
Sep 13, 2009 | Televison & Video
TV will not power on.
I guess your TV is DLP.
Please notice the follow symthoms:
When you on TV, did you hear some strange noise from the back of the TV. If yes, the color wheel needs replacing.
If no, check the lamp. Take a look to bottom of lamp, you will see white pot or sometime a pop up there due to lamp cycle is going to end. When changing lamp, check the ballast and power sup, too. If you see caps are poping up. Pull out those board and replace the poped caps.
Aug 13, 2009 | Televison & Video
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
Heard a pop and screen went black
Sorry thats the death of your tv I
m afraid, the pop you heard is either your lamp or tube going boom.
Apr 03, 2009 | Televison & Video
I have a Samsung 61 inch DLP tv. Was very happy with it for the past 3 years. Lamp went out in Feb. Got a new one and replaced. A few weeks ago, it started making a screeching noise. Fans were ok,...
It is b.s. but it's not only samsung that have poor reliability. At least they have some customer service. Some new brands are a nightmare. I would suggest changing the ballast first, and if that doesn't do it, you're probably looking at a dmd board which is very expensive. Only other thing I can say is to try removing and reseating the lamp switch again. Also listen for the color wheel to start up a few seconds after you push power on. Color wheel is started by dmd board, lamp is driven by ballast.
Jun 12, 2008 | Samsung Televison & Video
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
Sony KP-65WV700 65" Rear Projection HDTV Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
