Question about Polycom Computers & Internet
Airport extreme incompatible with polycom?
Got a new airport extreme router. opened proper ports, and verified 3 times with polycom placed polycom in DMZ i can call out and get calls in i CANNOT see or hear those i connect with but they CAN see and hear me Apple says it is not the router and that there is not a compatibility issue and to call polycom polycom says it is not the polycom and there is not a compatiblity issue with any router, and that it is just my router settings the polycom DOES have the proper external IP address, so my NAT settings are set up correctly When a tech connected the polycom directly to my modem it did work again. BUT, now that i am trying to connect to my old router as a quick fix for today, it is not working and i am getting a time server "down" error on the alert screeen of the polycom. HELP.
Posted by jenna on
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
Posted on Feb 13, 2008
Anonymous
SOURCE: PS3 - Wireless network problem
Check your bandwidth, you might not have sufficient speed to run the application, I got cable and the odd times I got booted too.
Welcome to the world of wireless frustration.
Posted on May 08, 2008
pontelemon
pontelemon
  • 538 Answers
SOURCE: Router/Modem IP
Try 192.168.1.1 or 172.16.1.1
Posted on Mar 20, 2009
Anonymous
  • 115 Answers
SOURCE: Remote Desktop via VPN problem
Make sure that the Active Directory setting for the User you are using to RDP with (LDAP FQN) has the remote access option turned on.
http://www.windowsecurity.com/articles/Securing_Remote_Access_Connections.html
Also make sure that the PC's you want to access have static IP addresses. Not sure if that was mentioned.
Posted on Jun 22, 2009
CoquiBiz
Juan Carlos Cabrera
  • 103 Answers
SOURCE: "Couldn't contact DHCP" error
Check on the router if you are distributing enough IP addresses.
Posted on Jul 30, 2009
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
Just got a new router (motorola) and airport will
Check your connections:
DSL-modem to telephone-jack (or cable-modem to cable-jack).
Ethernet cable from DSL-modem (or from cable-modem) to WAN port on your router.
Ethernet cable from LAN port on router to WAN port on your Airport.
Cut the power to the Airport, and then plug it back in, so that it restarts.
Apr 17, 2010 | Apple AirPort Extreme Router
Airport extreme that is constantly flashing green
yes if only one location has this problem, the airport has now top security level because of latest theaths. it's normal.
Dec 29, 2009 | Apple AirPort Extreme Router
I want ot disable DHCP on apple extreme router. Because MS 2008 SBS R2 scans for DHCP servers and fails to config if found an other dhcp server (apple extreme)
1) Open Airport Utility (Applications/Utilities).
2) Select the Airport Extreme in the left hand panel and press Manual Setup
3) Choose Internet in the top menu bar
4) Change Connection Sharing to 'Off' (Bridge Mode.
Press update to restart the Airport and save the settings.
Mar 16, 2009 | Apple AirPort Extreme Router
Airport extreme crashes a few times per hour
Try buying a brand new one. It might be older than you computer or it is the ISP causing the router to crash.
Jan 04, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom NetEngine 3300R Port Capabilities
You'll have to set up Port Forwarding on the router, to port forward a port from the 'local' zone to the 'internet' zone. And i do hope your not viewing the administration pannel on the thing in German. (polycom is german, as is their website)
Nov 29, 2007 | Polycom NetEngine 3300R (2200-30128-001)...
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
Computers & Internet Logo
252 people viewed this question
Top Polycom Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Darren  Means
Darren Means
Tom Chichester
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
