Question about Avanquest SUDOKU PUZZLE ADDICT: UNLIMITED EDITION (WIN 98,ME,2000,XP)
Need to reinstall or repair sudoku
I need to completely uninstall program, however, the program can't be found in my programs.
Posted by Yvonne L on
Aizirk Mae
    New Friend:
You can check the properties of the shortcut then check the folder path to locate the application.... then you can uninstall it:)
Posted on Dec 07, 2011
When i start coreldraw 11 I see the notice: >. What does it mean and how can I fix it?
It means your copy of this program has been corrupted.
Either try to repair the program or completely uninstall the software & reinstall it again.
Best of luck.
Mar 09, 2018 | The Computers & Internet
Why can't I remove the TLC Playtime for Baby and Toddler software program
Try re-installing the program. Reboot. Then try to uninstall with the programs uninstall and/or your operating systems uninstaller.
You may need to reinstall again. Reboot. Between the two different ways of uninstalling.
I have had programs not install the "uninstaller" the first time around, so is why I am suggesting you reinstall first, then uninstall.
Jan 20, 2013 | The Learning Company Playtime for Baby And...
I am installing quickbooks 2011 Pro and keep getting Error code 3371 status code 1
The 3371 error means that the software couldn't read the license information. possibly due to an incomplete install. You need to reenter the license; you may need to do a full uninstall and reinstall. Have the license available before starting.
First try just deleting the license file:
Close Quickbooks if it is open. Depending on your OS, search for the hidden folder with the license file and delete EntitlementDataStore.ecml . (You may need to enable viewing of the hidden folders. This is accessed via the File Explorer. Double click the Computer (My Computer in XP) icon (or Start > Control Panel > Computer) to open the explorer. Click on Organize and go to the Folders and search options. In the View tab, select Show hidden folders.) For Windows Vista or Win 7, search for C:\ProgramData\Intuit\Entitlement Client\v6.0 . In XP, you need the folder C:\Documents and Settings\All Users\Application Data\Intuit\Entitlement Client\v6.0 . Just select the file and choose delete then confirm the delete command. Launch Quickbooks and follow the on-screen directions for registering the program.
The MSXML 4 software may be damaged or missing. This program is on the CD; however it may be better to download it from Microsoft, http://www.microsoft.com/downloads/details.aspx?FamilyID=7F6C0CB4-7A5E-4790-A7CF-9E139E6819C0&displaylang=en . Try to repair the software with the command msiexec.exe /fvaum "%userprofile%\desktop\msxml.msi" (then press enter) with the above file saved to the Desktop. (Click Start or Start > Run, depending on the OS.)
If the repair doesn't work because the program isn't installed, install with the downloaded file. Otherwise uninstall it (Start > Control Panel > Programs > Uninstall) and then reinstall first the MSXML 4 and then Quickbooks.
If the above step doesn't work, then you need to uninstall Quickbooks completely. First uninstall Quickbooks from the Uninstall Wizard mentioned above. Then run the Clean Install Utility from Intuit, https://www.quickbase.com/up/bd9yykidd/g/r9/eg/va/QuickBooks%20Clean%20Install%20Utility.exe , to remove any information from the program that was left after uninstalling. Reinstall Quickbooks after clicking OK when the program says Quickbooks is ready for a clean install.
You could manually rename the installation files instead of using the Clean Install Utility but that would clutter your hard drive.
I hope this helps. Let me know if you need any help; if you do, please add a comment with your OS.
Sep 19, 2012 | quickbooks.com
Need help with missing libgimpui-2.0-0.dll file
The problem is you didn't completely uninstall Gimp before you installed it again so the Gimp install file got confused when it found some residual files or registry keys from a previous install and thus it skipped installing some files (libgimpui-2.0-0.dll was one of them for sure) You need to completely uninstall Gimp before you can install it again properly. Get a copy of Revo uninstaller from the link below and use it to uninstall Gimp for you. You should be good to go after that.
Revo Uninstaller 1.94 Link:
http://majorgeeks.com/Revo_Uninstaller_d5706.html
Jun 14, 2012 | Computers & Internet
Unknown to me, MS Office 2007 Pro Service Pack 2 downloaded and started to install. The first I knew was when I tried to open a Word document. It told me the instalation had failed. I have tried to...
Often when you try re-installing a program ontop of a program that is no longer working you will continue to have the issue, the best way to go about it is to make sure you've completely removed the program and the service pack before uninstalling it. First click start then control panel, then you're looking for either 'programs and features' or 'add/remove programs' depending on your version of windows. You should see Microsoft office there, as well as any service packs that have been installed for it. You may have to click 'view installed updates' on the left hand side to show the service packs.
Once you have completely removed office, as well as both service packs, and any other office patches listed. restart the computer, and begin a fresh install of office.
hope this was helpful.
May 31, 2011 | Computers & Internet
Sound problem in my intel d865gsa.Ive updated and reinstalled my sound driver sound doesnt work
Try to upgrade your BIOS, then uninstall and reinstall the sound driver again. If that doesn't work, you'll likely need a new sound card.
Mar 21, 2011 | Intel Computers & Internet
Friend was uninstalling programs to make room on hard drive. (I don't know specifically which programs were uninstalled.) DVD drive is now disabled. Device is identified in Device Manager as Optiarc...
Can you do a system restore? If not, here is something to try:
You may have caused a registry error. Try running a registry repair program, restart the computer after repair has run, then try reinstalling, after reinstalling, restart the system once again, then try DVD. Good luck.
Jul 11, 2017 | Dell Inspiron E1505 Notebook
Cannot repair or reinstall software for technisson photo viewer
1st u Download Your Uninstaller! 2008 and remove program from Your Uninstaller! 2008 and then trie to re install the program
Jul 22, 2009 | Computers & Internet
What is program code of sudoku in turbo c
Hi, You can download the source code of Sudoku in C from below link:- http://www.techfinesse.com/game/sudoku_solver.php
Thanks! Sandy
Apr 21, 2009 | Computers & Internet
Avanquest SUDOKU PUZZLE ADDICT: UNLIMITED EDITION (WIN 98,ME,2000,XP) Logo
81 people viewed this question
Top Avanquest Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you an Avanquest Video Game Console and Game Expert? Answer questions, earn points and help others
