Question about HP Compaq Presario CQ50-110US Laptop
Flickering monitor - HP Compaq Presario CQ50-110US Laptop
Posted by FORREST PARKER on
  • Matt Walker
    Matt Walker Dec 01, 2011
    If you plug in a computer monitor or projector, does the video also flicker on that also flicker?
Catalin Turcu
  • HP Master
  • 4,924 Answers
It will have the same image if the fault on the monitor is caused by the video card ..but if the flickering is caused by a display fault ..(inverter or something ) the signal in the external vga port will be proper and the image clear .remember to enable the secondary monitor if you try to use it ...It may be disabled by default ..It has a F key for that and you have to press Fn =that kay ..or just go to the video card settings and select display ..and click on the monitor no2 and enable it ..also select clone mode for to have a full picture of the desktop
Posted on Dec 01, 2011
Flickering monitor, but laptop functions fine
Flickering monitor but laptop functions fine
Might be a bad monitor or the wron driver. Check your monitor on another computer, if still flickering, you should take it to repair.
Jun 24, 2015 | Computers & Internet
Dell desktop monitor screen flickers.
The monitor is about to go bad. Replace it. Borrow a monitor from a family member, neighbor or friend just to see if the flickering stops. If it does stop your monitor is bad. If the borrowed monitor flickers, you will need to replace your Video Card in the computer.
May 01, 2012 | Dell Computers & Internet
Desktop monitor flickering
My monitor is flickering
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software monitor may flicker and goes into rolling state due to dust, overheating after a long continuous usage,loose circuitry or due to some electromagnetic interference with other like tv , UPS, large speaker systems etc.
FIX :
1.Try Re-installing your Video driver
2 If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
3. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
4. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
If you don't think any above possible reasons for the rolling or flickering state of your monitor then we recommend you to get your monitor checked by the monitor company at their respective service cente
Sep 01, 2011 | LG Studioworks 700S 17" CRT Monitor
My BenQ G2220HD Monitor flickers. I've tried my level best to solve this problem but could not get rid of the flickering.
Try connecting it to a different laptop/desktop, to see if the flickering "follows" the monitor. If not, then the video-card in your computer is the problem -- try connecting another monitor to your computer, to see if the flickering still happens.
Sep 02, 2010 | BenQ G2220HD Monitor
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Flickering picture
chech out some other devices near by to the monitor, they might cause interfearence and in a result your monitor flickers.
1. If there is nay CVT/UPS near your monitor put it away.
2. If you have any speaker without magenetic sealed it will cause flickering, keep it away from monitor.
Otherwise your monitor need to be get service. So please contact your manufacturer service centre.
Thanks
Iqbal
Mar 30, 2008 | Gateway FPD2275W LCD Monitor
Monitor Flickering
If you have some electrical equipments like CVT, UPS near to your monitor, please put them away. If the flickering is due to the maganetic interfearence then it will solve your flickering of screen. and even after this if you are not able to use your monitor buttun then please call your technical expert b.coz your monitor may got some physical problem.
Thanks
Iqbal
Mar 08, 2008 | BenQ FP567s 15" LCD Monitor
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
HP Compaq Presario CQ50-110US Laptop Logo
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
