Bad RTC can be repaired. the machine is equipped with multiple sensors inside. if one of them goes bad, tamperring or bad rtc will come up. call us (775)358-2922 we can help you. thanks
Bad RTC and Tamper can be repaired. the machine is equipped with multiple
sensors inside. if one of them goes bad, or the Battery is dead
tampering or bad RTC
will show this can be fix by replacing the sensor and or the battery if
you need this to be done call me @ (775) 358-2922 hope this help : - )
Maybe your internal battery is already LOW that needs replacement. And cleasr the tamper by reloading Verifone Software. If you still needs help you can cal at (775)358-2922 as for Randy. Thank you. http://freshpoint.org
Tamper is cause by the bad internal/system battery that need to be replaced or you a bad plastic case which triggers the internal sensor on. We need to reload the Verifone Software to clear the tamper error. If you still need help you can call (775) 358-2922 ask for Randy. Thank you. http://freshpoint.org
Verifone units has multiple sensors built inside for security reason. If you acceidentally dropped or jarred the unit, the sensors will kicked-in and give that error that you have now. And i'm also thinking about your internal system battery is getting low too and needs to be replaced. Then we need to reload the Verifone Tamper Removal Software to clear the Tamper error. Tamper error can be cleared, if you still need help you can call us @ (775) 358-2922 ask for Randy. Hope to hear from you. thank you.
VeriFone provides a clear tamper application to its service centres. you would have to locate a service centre closest to you to have that error cleared.
Verifone has a built in safe-guard against tampering. There are certain things that can cause the new Vx Series of terminals to display this error - from someone actually tampering with the terminal, to a physical drop or jarring of the terminal.
I hate to be the bearer of bad news, but the ONLY way for a terminal to be unlocked when displaying "Tamper" is to send it into an authorized service center. I have many of these devices in the field for customers and have dealt with this issue a few times - unfortunately, that's the only way Verifone set it up for this error to be resolved.
