I turn it on and there's a static sound and no picture. The little light at the bottom turns blue, so it's definitely on and when I press "Input", the light blinks like it normally does. What's happening?
SOURCE: TV clicks off, sound comed back on but no picture
I had the same problem. I replaced 14 capacitors on the Power Supply board. I used Panasonic series FC from DigiKey. If you see any capacitors that are swollen or have any substance oozing out for sure replace them. My set had lots of the brands that are known to have problems so I replaced all of them even though I could see no obvious swelling etc. Make sure you carefully label the connectors etc when you disassemble the unit.
SOURCE: tv wont turn on, but have light on fornt of lcd
You are only have 5v standby circuit working, the problem can be in the main control board (not sending signal to turn on the main power supply sections) or the main power supply sections are bad.
SOURCE: FLM-3201 will not turn on
You can download service manual here:
http://www.polaroidsupport.com/polaroid/en_us-sm.html
Look for bad capacitors, burnt parts in the power supply first.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Testimonial: "On the mark about the bad capacitors!"
SOURCE: Blue LED light comes on but nothing else happens when turned on
It can be the main board or the power supply,
look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
SOURCE: the red power light is on.. i press the power
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Testimonial: "its in the power supply board.. i have no experience in soldering or any of that kind of work.. know where i can buy a supply board?"
