Message to particular number is not sending,because in my nokia 2690 mobile recipient handset memory is full,so how i want to overcome this problem,please help me
hi restriction codes is nothing but the mobile is restricted to particular network to solve the problem we can use codes to unlock .you can get the codes from here wickedunlock here they ask the following details they are mobile model,country and the network which locks your mobile ,imei number of the mobile .finally they will send the codes to unlock your nokia 2690 mobile.once you entered the codes in your mobile your mobile get unlocked and it will be free to accept any network sim.
You just need to call the customer care then tell them that to send internet settings for this number or they will tell you send a message send that message to given number.With in few minutes you will recive the settings.After reciving the setting switch off you are phone for a while.Then switch on your mobile from that time you can use internet in your mobile.Thanks for your question.
Actual your question is uncompleted. What is to be loaded from the PC and as per PC comments you are requested to set write/installed the particular software then only your cell phone is downloaded movies and etc
this is the probem due to either the coverage of the n/w in the particular area is less or the handset memory for the n/w configuration list is full like the way if the bluetooth pairing with number of handset if full the pairing doesnt happen.
Hi, you can delete selected message recipient by using Conversation View in Nokia X3. Please open Messages menu and select Conversation view, now select option on any message recipient then select Delete Conversation to delete the messages sent by a particular recipient. You can delete Calls from the log by opening Log Menu and selecting "Clear Log lists". You cannot move any Messages directly to the Memory Card or to a folder in Memory Card. However you can backup all Messages, Contacts, Calendar, Notes...etc to the Memory Card by going>Menu>Settings>Sync & backup> Create backup option. This will create backup on which you select like Messages, Contacts...etc to the Memory Card. You can restore the created backup by using the "Restore backup" option in the same Sync & backup Menu. It is also possible to restore the backup by directly opening the backup file which you have created in the Memory Card.
sir in nokia 2690 phone.in the inbox message right click and mark the messages u want to copy.and then copy the message to the simcard [not in the memorycard will not accepted pc also not accepted] u copy the message in simcard
