SOURCE: jensen vm9510
Attach the pink wire to the red power wire to see if unit comes on. If does then no attached correctly to emergencing brake wiring.
SOURCE: hooking up backup camera to jensen uv8
That wire needs to run back and be hooked to the revese bulb. When the car is in reverse, activating the reverse lights the unit will get a signal knowing that you can use the camera
SOURCE: Where do I hook up the pink wire in a 95 Toyota
if the pink wire mark to brake just connect to a straight ground or to a switch to a ground in put to switch
SOURCE: to wich cable do i connect the pink park cable
you have a indash tv
all u do is hook the pink wire up to the grownd wire and it will play while your driving
