The clock will not keep the correct time. I have a Sony IFC-218 clock radio. The clock stays 8-9 minutes ahead of time. Do anyone have a suggestion as to how to resolve this issue? Thanks. Aaron
SOURCE: I have 2 clocks (model 40009,40010)that have inaccurate time
INSTA-SET TIME IS INCORRECT: First check that your Time Zone and DST settings are correct. If the time is still wrong you can manually set the Time and Date:
DAYLIGHT SAVING TIME: ON is the default position. If your area does not observe DST changes, then press and release the DST button on the top of the clock, the press the PLUS button to turn DST off.
SOURCE: Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
SOURCE: 12:33 keeps flashing
Hi - You can download the manual from the link underlined in blue below:
RCA RP5420
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: my sony radio alarm clock is too fast about 1 hour
alarm clocks works on frequency and not only on voltage.if it is original 110v 60htz and you trying with 220v 50htz supply then it wont work correctly
