Question about Brother HL-2040 Laser Printer
HL-2240 reset toner
Toner light is on - can't print. Replaced toner. How to reset?
Posted by lou ann obrien on
xello66
    New Friend:
Great!
Posted on Nov 04, 2012
Dean
    New Friend:
  • 25 Answers
Hi, I had the exact same problem, drove me nuts :) Anyhow, after some research, I stumbled upon the official manual and it helped me. You can find it here - Brother HL-2240 manual
Posted on Nov 17, 2013
  • Dean Nov 17, 2013
HateToRegister
    New Friend:
jocelynwater
    New Friend:
Thank you! That reset works! Brother walked me through that one time. None of my other Brother printers did this. This feature is a ploy that Brother created to sell more cartridges, undoubtedly.
Posted on Sep 12, 2012
5 Related Answers
Anonymous
SOURCE: Brother HL-2040 toner light stays on
I found this and it worked great.
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Posted on Nov 27, 2009
Testimonial: "Thanks!"
Anonymous
  • 8 Answers
SOURCE: We've replaced the toner on a Brother HL-2150n
Most Brother printers need manually reseting when either the drum or toner is replaced. Sometimes it doesn't need it and sometimes it does. Don't ask me why because I have no clue lol. What you do is open the Front Panel button that corresponds on the top with the blue botton. If you hold it from the inside of the printer until all the lights flash ontop of the pritner, then you let go and close the door. This should reset the printer. I hope this helps and I explained myself well lol
Posted on Jul 01, 2010
Anonymous
SOURCE: Brother printer Hl 2070. Toner
From Brother.com: Description:
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover.
Caution
    Reset the drum counter only when you replaced the drum unit with a new one.
Posted on Jan 09, 2009
Anonymous
  • 12 Answers
SOURCE: Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
Posted on Jul 05, 2008
Soulvisitor
Soulvisitor
  • 1113 Answers
SOURCE: HL-2040 CHANGE TONER
Changing with brand new brother never used drum and toner and reseting drum counter should fix
light expalin link
Posted on Dec 22, 2007
Toner light on, replaced toner cartridge, won't print, toner light still on, replaced with new cartridge, toner light still on and won't print.
unplug the printer for about 5 minutes thne remove the cartridges then after five minutes put the cartriodges back ion and power on the printer and after that check if you still have the toner light on if not try to print ....
Oct 30, 2008 | Brother Office Equipment & Supplies
I have a brother HL-2130, the toner light came on and the printer doesn't want to print anymore, even after i have replaced the toner with a new one. Can anyone give me some advice please?
This WEB site shows how to reset your printer after install a new toner.
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002500/000017/faq002517_003.html?reg=us&c=us_ot&lang=en&prod=hl2130_all
Apr 03, 2012 | Brother HL Office Equipment & Supplies
Replaced toner but toner light still on .
You sometimes need a code to reset the counter on your printer. Which code depends on your model.
Mar 01, 2011 | Brother HL 2140 Laser Printer
I have a Samsung ML-2525 BW laser printer. Recently, the red bar second from the top started flashing and then it went solid. I thought this was because of the ink toner, and the cartridge was running low...
I guess it FixYa didn't accept my (very long, but totally correct) solution that I took the time to type. Because I refused to "sign in".
Here's the short version. Load Paper. The same thing happened to me. I replaced the toner cartridge with a new one (because of a FLASHING red light for several weeks) after the red light went to STEADY red. But it still would not print. The paper was "out". When I'd refilled the paper-tray, it printed fine. I had just ASSUMED that the steady-red light meant toner was finally OUT. WRONG! That steady-red light had nothing-to-do with toner; it meant "you're out-of-paper". Don't get confused like I did. Refill the paper-tray. Then take that expensive NEW toner cartridge OUT, and put the OLD toner cartridge back in. And keep using the "dregs" of the toner out of the old cartridge for several more weeks. And DON'T get confused by the paper-is-out condition making that red light STEADY.
Nov 01, 2010 | Samsung ML 2525 BW laser Printer
The printer quit printing and the toner light came on. Replaced the toner with a brand new toner and its still not printing. Recommendations?
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Mar 04, 2010 | Brother HL 5250DN Laser Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Toner light will not go off
Take the drum/toner out and with the front cover open press the blue 'go' button once, then put the drum/toner back in and press the button once again, then close the cover.
should reset the toner for you
Nov 10, 2008 | Brother HL-5240 Laser Printer
Brother HL-2040 Laser Printer Logo
13,159 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
