Question about Nikon Coolpix S3000 Digital Camera
Nikon S3000 dosent turn on
My Nikon S3000 dosent turn on, It dosent respond if i try to charge the battery either. It worked fine a week ago, I havent dropped it or anything. Any help would be appreciated!
Posted by Jane Hatfeild on
Kelly
    New Friend:
    Problem Solver:
  • 6 Answers
Have you updated the firmware? According to Nikon, when the Rechargeable Li-ion Battery EN-EL10 is inserted in the camera and charged, charging sometimes did not stop after the designated amount of time had passed. Usually, you'll receive the message "Battery Exhausted" if this is the problem... but you could also have a completely dead camera as well.
See Nikon's website, download updated firmware to your camera and install a NEW battery. http://support.nikonusa.com/app/answers/detail/a_id/16873
Posted on Dec 06, 2011
My camera says battery exhausted after charging replaced with a new battery its doing same thing after about 2 weeks
The problem may be with your battery charger rather then the battery itself. I don't know if you are charging your battery in the camera or with a separate charger. In either case I would buy an external charger. If you don't want to spend Nikon money. Adorama.com has several models in the $20 range. Try charging your battery in a new charger. If that does not solve the problem, there may be a short circuit in your camera's electronics that is draining the battery. If that is the case, contact the Nikon USA Service Center (look on the Nikon website) for a repair estimate.
Jul 02, 2014 | Nikon Coolpix S3000 Digital Camera
WHY MY NIKON COOLPIX S3000 FLASH NOT WORKING?
okay let mi think....
you cant charge a nikon camera via usb port the usb port is data only
please reply and try to use a nikon coolpix s3000 charger
Feb 22, 2013 | Nikon Coolpix S3000 Digital Camera
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
Nikon Coolpix won't charge no matter what
The internal battery, which is kept charged by the removable battery, has probably run down. Take it to a repair facility.
Apr 25, 2017 | Nikon CoolPix S4150
Nikon s3000 was working fine,the battery ran low and then i didnt use it for a while and now i have just gone to charge it up and its not responding at all. no green flashing light. and when i connect it...
It is possible that the battery voltage has drained and gone below the threshold limit. In this case it will not recharge as it had drained too much and so will need a JUMP START. What can be done in this case is to use a multimeter to confirm that the voltage is indeed low. if so use test bench charger with a series limiter resisitor of about 22 ohms to apply a voltage to the respective terminals- correct polarity.
Once the battery voltage comes up then the charger can be used to charge to the normal level.
If the camera does not come on place the set with the charger for some time. If not there is failure within and must be checked out consulting the Nikon service center.
Sep 17, 2011 | Nikon Coolpix S3000 Digital Camera
One day i tried to turn on my camera but it wouldn't turn on, my camera is a nikon coolpix s3000. i dont have a memory card and the battery wont charge. its like a block battery it has the...
Please check the voltage on the battery using a multimeter. Now if there is no voltage try and charge and test with the camera , if the camera powers and then shuts off then it is possible that the battery is faulty. If so it must be replaced, check if warranty is applicable.
Aug 08, 2011 | Cameras
My nikon S3000 has been giving me many problems ever since I bought it. My latest problem is when I turn it on one day, it indicates that 'battery exhasted', but I had fully charged it previously. And...
Rechargeable batteries don't last forever and the ones supplied with the camera are not of very good quality. Try new batteries and also consider getting another recharger as the Nikon supplied one is very basic and does not take good care of the batteries it's used with.
Mar 24, 2011 | Nikon Coolpix S3000 Digital Camera
I have a brand new Nikon coolpix s3000. This is my first time attempting to uplaod the pictures to my computer. My camera has been saying that the battery is exhausted all day, so i figured if i plugged it...
Your camera came with a separate battery charger, didn't it? Plugging a camera with a dead battery into a computer won't get you very far. Charge the battery first.
Jan 18, 2011 | Nikon Coolpix S3000 Digital Camera
My Nikon Coolpix S3000 says battery exhausted, but when I plug into charge it won't charge. Any suggestions?
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
Jan 14, 2011 | Nikon Coolpix S3000 Digital Camera
Nikon Coolpix S3000 Digital Camera Logo
191 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
