hi, to give quality display grafix for games you must have video card which is geforce 9 series and it has 1g with 256 bit.... and the minimum of 1g-128bit.. that will give you best for the games...
The video card is a joke, strictly for office use. Get a GTS 250 , it's an very upgraded form of 9600GT. 8800GT is far too old and weak for newer games.
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Suggest you test your geforce 9500 GT in another system or try another PCI-Express video card. Try cleaning the contacts of your 9500 GT with alcohol, allow it to dry. Do not touch the contacts with your fingers after cleaning. If your onboard graphics functions correctly than it may be the 9500 that has a problem.
Look in the BIOS, under the video ram settings. What is the largest RAM it can handle? 128? 256? 512? This will give you an indication as the size of video RAM that you can have on your card.
If you are using Dual Core the mother board you are using may have PCI Express Slot. So that you may install Graphics card. Only for particular lower end mother board doesn't have this feature. Any way tell me your motherboard make and model no. e.g., Intel DG31PR, 945GNT, DG41TY etc.,
Yeah maybe but it gonna be SLOW so I dont recommend it. you should have a better computer.
Resident Evil 5
Publisher: Capcom
Developer: Capcom Minimum System Requirements
OS: Windows XP
Processor: AMD Athlon64 X2/Intel Pentium D series
Memory: 1 GB
Hard Drive: 8 GB Free
Video Memory: 256 MB (ATI Radeon HD 2400/NVIDIA GeForce 6800)
Sound Card: DirectX Compatible
DirectX: 9.0c
Keyboard and Mouse
DVD Rom Drive Recommended System Requirements
OS: Windows Vista
Processor: AMD Phenom X4/Intel Core 2 Quad series
Memory: 2 GB
Video Memory: 512 MB (ATI Radeon HD 4800/NVIDIA GeForce 9800)
DirectX: 10
Keyboard and Mouse
DVD Rom Drive
hi..if u want to run as good that VGA u need to set in the Bios as init fist display as AGP then find what AGP size appear on bios..if this all OK try to booting the system..thanks and Good Luck..^_^
