SOURCE: Recovery Disk for Acer Aspire 5315
No, Acer no longer supplies the recovery discette off the bat. However if you call their customer service they can send you one.
SOURCE: Acer Aspire 5315 laptop, Ubuntu, microphone
This is due to the drivers. This will require a kernel build and the drivers to be checked. check the Ubuntu forums for a kernel build for your Acer there should be a script to correct this already written.
SOURCE: Acer Aspire PC Notebook 5315 touchpad not working.
Hey in the control panel, go to the mouse, then look for the properties that have a PS/2 compatible mouse, you can change its settings there by sellecting other compatible mouse instead of PS/2, and also there is a settings or a check box that says the onboard mouse of your laptop will be disable if a usb mouse will be pluged.hope it soved your problem, :)
