The words are blurred because it is double or tripple printing on top of each other. Some lines are totally illegible and some are perfectly clear. Some lines are just )))))))))))) or another symbol
If there is enough ink , print a test page if same problem is there check printer's setting .. or re-install the printer ,ah sometimes the files are encrypted wen u print it will not be print out properly...
Soon it will give you an error code on display or ill be observed on your computer. The print head nozzles are not firing correctly. The only way to remedy this is to:
1. Have the printer serviced and cleaned ( the cost of the new print head and a cleaning and servicing of the printer
2. Order the print head online and install it yourself. The wonders of the internet can find an give you a video of how to do this.
The part number is:
Canon QY6-0082-000 Printhead (Canon QY60082000 Printhead)
I hope this helps, Steve
After open it, Follow the given Installation Instructions: Download
the version of the driver that corresponds to your operating system by
clicking on the appropriate link above. A window should then show up
asking you where you would like to save the file. Save the driver file
somewhere on your computer where you will be easily able to find it,
such as your desktop.Now Go to the location where you saved the file and
double click on the file. Then simply follow the on-screen instructions
for installing the driver.Further assistance i am here to help I hope this solution helps you Thank you for using FixYa!
canon mp490 error 5200 solution...... turn off printer,then hold reset button(the red 1 circle with triangle in middle) for 5 sec then whilst holding reset button turn power on let go of reset button then push reset button twice whilst still having hold of power button then release power button then push reset button 4 times and then power button twice hope it works it did for me carlos:)
Try cleaning the felt pads where the print head would rest when not printing. They get full of ink and cause more printing problems. I use water to clean them.Don't loose them, they are needed to keep the print head from drying out.
