I need for you to tell me how to open NAT on my xbox so I can use it for xbox live. (be specific)
1 Make sure your ZyXEL Device hardware is properly connected (refer to the Quick StartGuide).2 Prepare your computer/computer network to connect to the ZyXEL Device (refer to theQuick Start Guide).3 Launch your web browser.4 Type "192.168.1.1" as the URL.5 A window displays
6 For administrator access enter the default admin password 1234 to configure the wizardsand the advanced features.(or if you already changed your password, enter that password)7 On the right hand side of the screen you will see a drop down menu. click on NETWORK. 8 Then click on NAT.9 Find the area to configure Port Forwarding.10 The ports that Microsoft recommends to be open are:88 UDP3074 UDP3074 TCP
It also looks like you will have to set up a static address (I was looking at the .pdf for your particular router) You can do this by editing your network setting on your XBOX console, and then using this address as your "server" address when opening the above mentioned ports on your router.
ftp://ftp.zyxel.com/P-660HW-D1/user_guide/P-660HW-D1_3.40_Ed1.pdf
SOURCE: i need to open the nat on my router for xbox live and dont know how
go into the router settings and look for uPnP and enable this it will then open the firewall for your xbox automatically
SOURCE: motorola router nat not open for xbox live
Configuring the Firewall for Gaming
By default, the SBG900 firewall is disabled.
If, as recommended, you enable the firewall, refer to the game’s
documentation to ensure that the necessary ports are open for use by that game.
The pre-defined SBG firewall policies affect X-Box LiveTM as follows:
LOW: XBox Live data can pass through the firewall. No user action is required.
MEDIUM or HIGH: To enable X-Box Live traffic to pass, you must configure:
• Choose Custom on the Firewall > POLICY — basic Page
• UDP 88:88 and UDP/TCP 3074:3074 on the Firewall >
POLICY — advanced Page
Configuring Port Triggers
Because the SBG has pre-defined port triggers for games using any of
the following applications, no user action is required to enable them:
• DirectX 7 and DirectX 8
• MSN Games by Zone.com
• Battle.net®
For a list of games supported by Battle.net, visit http://www.battle.net.
You may need to create custom port triggers to enable other games to operate properly. If you set custom port triggers and enable the firewall, you must customize the firewall to allow traffic through those ports.
To create custom port triggers, use the Gateway >
PORT TRIGGERS — custom Page.
SB900 USER GUIDE
The motorola guide has more information relating to port triggers.
If you download the pdf file, go to page 27 for Firewall settings and Page 35 for Gaming Settings..
More indepth information is there.
Hope that helps
Mike
SOURCE: restricted nat for xbox / linksys 160n router need to open
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here to know more about router and network
What type of router do you have?
