My documents are printing, but part will be normal and part will be too light to read. I'm assuming maybe one of the ink cartridges is getting low. I used to be able to check ink levels on windows vista, but now on windows 7 cannot find it anywhere. Do I just have to guess which cartige is low or if that is the problem?
SOURCE: Cartridge not detected
Change ink! It has a sensor that stops operation to ensure ink lines remain with ink in them
There should always be ink left in cartridge otherwise the printer would suck in air and air would turn in to bubbles in the ink line which become blank areas on your printing.
SOURCE: compatability epson r300/vista
Did you go to Epson.com and check for upgraded drivers for Vista?
SOURCE: Computer won't recognize a replaced ink cartridge
This is what worked for me today..
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button until "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semi full Reset" is displayed.
5) Press OK.
Now, check the functionality of the All-in-One. If the issue persists, please perform the next troubleshooting steps
Courtesy of Joe at HP via an email
SOURCE: Reset ink level for HP 460
try this, if you are in a windows environment, click your start button, select control panel, then double click printer, then right click the name or model of your printer, then select properties, then select maintenance, and then select ink settings. thats it
SOURCE: Brother MFC 5440CN Low Ink problem
Maybe you can try reinstalling the driver or if the cartridge was bought from 3rd party, you might want to buy one directly from the manufacturer.
Good Luck.
