SOURCE: Wacom tablet (Model ET-0405-U) Driver?
see i am having the same problem. i am runing windows xp but the tablet light is yellow and does not go green. and does not work at all i have also downloaded et driver.
SOURCE: Wacom Tablet Blueberry ET-0405-U I
What you will want to use is the windows vista drivers that are available from Wacom
http://www.wacom.com/downloads/driver-detail.php?id=178
If the drivers fails to install windows it will start the program compatibility assistant. Click the button that says: Reinstall using recommended settings. Hopefully that works for you.
SOURCE: Hi, I need a driver for
Hello
Try to download from:
You didn't specify the Vista version (32 or 64 bit), but 99% the 32 bit driver version will be OK. The producer suggests to uninstall the previous version of driver if one is already installed. (to uninstall, go to Control Panel, Programs and features and double-click the item that looks like "Wacom..." or "Graphire...")
Good luck
