To wire a Dean Edge bass guitar with four pots (potentiometers) and a battery, you will need to follow the wiring diagram for the specific model of your bass guitar. Here is a general overview of the wiring process:
Start by connecting the ground wires to the pots and the battery. The ground wires should be connected to the ground terminal on each pot and the negative terminal on the battery.
Next, connect the power wires to the pots and the battery. The power wires should be connected to the positive terminal on the battery and to the power terminal on each pot.
Connect the pickup wires to the pots and the output jack. The pickup wires should be connected to the pickup terminals on the pots and to the input terminals on the output jack.
Connect the control wires to the pots and the output jack. The control wires should be connected to the control terminals on the pots and to the output terminals on the output jack.
Test the wiring to make sure everything is working properly. If there are any issues with the wiring, you may need to double-check your connections or consult the wiring diagram for your specific bass guitar model.
It is recommended that you follow the wiring diagram provided by Dean or consult a qualified technician if you are not comfortable wiring the bass guitar yourself. Improper wiring can damage the guitar and potentially pose a safety hazard.
Go to either Fender, Gibson, or another guitar company, and look up wiring diagrams. Anything with 2 humbuckers and a switch is wired essentially the same.
can be a number of things . i'll do my best with a check list. 1. Are they active pick ups.? (they need power source , usually 9 volt battery). 2. Check your cords. 3. check your amp. ( what i do, if you can, use a guitar that you know works. and check cords and amp with that. or try your guitar thru a different amp).AND THAT'S IF,. as you say your wiring is correct , and you've eliminated that part of it .I'd start with that
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
* Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
http://www.guitarjamdaily.com/index.php?option=com_content&Itemid=46&task=view&id=318 Try this if you feel comfortable doing it yourself.Otherwise your local music store might be able to recommend a good luthier in your area.
