Thanks! Coffee spilled behind the clear plastic faceplate discoloring the display and cracked the faceplate. I'm trying to figure out if I can remove the faceplate to clean behind or if I can relace the cracked faceplate. The radio works perfectly. W
SOURCE: stick auxiliary box lid
This is a known failure item. Take it to a dealer & have them replace it under warranty. I personally have changed 20 or so. The replacement boxes seem to have been upgraded, and do not display this issue any longer.
SOURCE: 2006 toyota camry JBL radio; controls don't work
THIS IS A RADIO PROBLEM, THIS PROBLEM WILL REQUIRE THE RADIO BEING SENT OUT TO AN AUTHORIZED FACTORY ELECTRONICS REPAIR CENTER, THERE IS NO BLOWN FUSE OR THE RADIO WOULD NOT EVEN TURN ON.
SOURCE: How to remove radio faceplate on 2003 Toyota Camry?
U don't have to remove anything, just get a laser lens cleaning disk from any store that carries music CD's Walmart has them for about $6
SOURCE: text button does not work
When you insert a cd that has folders of MP3's it's suppose to display the music info., IE., artist, album,
