Question about Sony FD Trinitron WEGA KV-27FV310 27" TV
Have sony kv27fv310 fr trinitron wega- turned it on and red light blinks and then shuts off. Sony tech recommended unpluging from wall, wait for two minutes and replug and it worked for about 4 days. Have problem again so hit the display - channel 5 - vol minus button and power and it works. Problem is that it takes from 15 minutes to an hour of trying for it to kick in and start working
3 Suggested Answers
6ya staff
SOURCE:
ABRsvcs
  • 4234 Answers
SOURCE: Sony Trinitron wega KV27FV310
Sounds like a problem with the vertical circuit. If yuo can solder and are comfortable with working inside the set, you may be able to repair this.
Keep us posted.
Dan
Posted on May 23, 2008
Anonymous
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Trinitron Wega TV keeps shutting off and red
There are two Ic's that need replacing on the Deflection Board (D) board.. These regulate power for the High Voltage and Chopper PWM circuits. The IC location on the board are IC6501 and IC8002
Nov 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Tv turns itself off after 5 seconds...blinks 7 times?
Had the same problem. Unplug from wall for 36 hours and then it works.
Hp Sydney Aus
Aug 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36HS500 blinking red light 6 times
smack it on top a couple of times, it works for me :)
if ya cant duct it, smack it...
seriously...
Jun 29, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Wega
Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KV 32HS420 SONY WEGA TRINITRON
Shorted diod D503 next to HOT on main board
Apr 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-27FV310 27" TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
