As normaly turned on harddisk.. not i get a mgs saying: disk cannot be used, format 1st.. but i dont want to format almost 1TB of data is stored here.. it doest show up in my disk list either.. but sometime it says now "you need to format the disk in G: drive before u can use it" help !!
Try running fix disk on start-up.
Posted on Jan 13, 2018
Hi
please explain more information about your problem.
before any further assistance try to check it on other computers and see if its working or not if yes then take a full backup quickly,
if not then:
try replace the USB/SATA/PATA cable and check if it is working or not.
if not then:
1-this is an external drive:
1-1: it use as a normal external HDD for backing up data/movie/music/pics/etc.:
option number 1:try to fix its partition clusters/sectors with some software like easeus partition recovery or ...
option number 2:try to format it and then recover its data via recovery applications like easeus or "get data ntfs back" or...
note: in all scenarios you may lost some files or content
1-2 it is used for speed up your computer or has the MBR or EFI boot partition and has an OS installed on it:
try to fix its partition clusters/sectors with some softwares like easeus partition recovery or ...
2-this is an internal drive:
1-change the SATA/PATA cable
2-check its sectors or clusters via software (windows check disk or windows defragment option) for bad sectors or cluster issues
3-try to fix its partition clusters/sectors with some software like easeus partition recovery or ...
if none of my solution works or software found some bad sectors that could not resolve it then or even you couldn't format the drive then:
maybe it has a hardware fault and there is not much you can do about it by yourself and you should go for warranty service or replacement or asking some expert companies for recovering your data via some special hardware that it may cost you too much.
best regards
SOURCE: Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Posted on Mar 09, 2008
SOURCE: Lacie 1TB External USB Drive tells me to format when I plug it in
I finally found a solution. I used GetDataBack, it was easy to get, I used the usual torrent sites to get it, and it recovers your files from your hard drive if you have problems with it (i.e. can't access it, etc.). I think my problem was caused by pulling out the usb cord without Safely Removing the hardware,
Posted on Sep 26, 2008
SOURCE: ps3 and 1tb hard disk
This one may only have one possible solution.
You probably have heard that the PS3 will support up to a terabyte hard drive. That is true for most of them.
However, depending on the version of PS3, you may have to see if it is possible to flash the BIOS of the PS3. I talked to a Sony representative about the hard drive and it will support a 1 terabyte hard drive.
Contact sony to see if it is possible to flash the PS3 BIOS so it will recognize the drive.
Posted on Jul 27, 2009
SOURCE: Windows XP won't recognise LaCie 320g Rugged Hard drive
Based on windows you should go to the control panel, system,administrative tools, computer management and then select disk management.
If you drive shows up here and says healthy then you may just need to add a drive letter.
That can be done from where you are just right click on the drive and use the change drive letters paths option and use the one that windows offers you.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Posted on Sep 08, 2009
SOURCE: My Lacie external drive no
If you are running Vista, you might be one of many people who are
reporting an update that is causing some buggy behavior. Try this:
Connect the drive but do not format the drive, right click 'my
computer' then 'manage' go to 'storage/disk management' view the
drives; your usb drive may be shown but will not be allocated a drive letter. You can
set one manually or leave it for about 2~5 minutes for one to be
allocated auto. Each time you connect the drive you may have to do
this.
If this is not your solution, then you need to run a disk partition
utility to recover the inaccessible data from the damaged or corrupted root directory structure, boot sector, master boot record and file allocation table entries to access your files
again. I recommend commercial products from either Acronis or Paragon, or a google search adding the word free to some of those keywords I just used.
Hope that helps.
Posted on Oct 16, 2009
Jul 29, 2015 | Matsunichi 1TB USB 3.0 Portable External...
Aug 22, 2014 | Asrock 845GV (P4I45GV) Motherboard
Jun 18, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
Oct 05, 2009 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
Mar 12, 2009 | Western Digital My Book Essential 1TB...
Feb 26, 2009 | Dell Latitude 110L Notebook
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
May 31, 2008 | SimpleTech 1TB External USB 2.0 Hard Drive...
Mar 12, 2008 | Computers & Internet
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
Mar 15, 2019 | LaCie Computers & Internet
125 people viewed this question
