Question about HP Compaq Presario CQ50-110US Laptop
Left touch pad button
It only words some of the time, usually a few minutes after restarting then I have to revert to double tapping the Touch Pad.
Posted by Jody on
5 Related Answers
Murphybanton
Onifade Adewunmi
  • 2004 Answers
SOURCE: HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
Posted on Apr 10, 2009
Anonymous
  • 2600 Answers
SOURCE: cannot tap touch pad
There is not a whole lot of information that you are giving us. There would be two reasons the touchpad does not work...one, there is a small button above the touchpad and if it is red (orange) the pad is off and you have to tap that button until the light turns blue. If the light is blue, then the tapping part of the pad has been turned off in mouse properties. Open control panel > mouse Properties > device settings > click on settings button and enable tapping. All other touchpad settings are in there to modify also.
Posted on Sep 12, 2009
Anonymous
  • 124 Answers
SOURCE: cant scroll up or down with my touch pad on the
1st goto control panel mice& pointing devices Find your touch pad go to advanced settings check that auto scroll is enabled if its not enable it. If this corrects the problem youre good to go otherwise find the updated driver from hp. Just a note control panel has to be in clasic view mode
Posted on Nov 14, 2009
Testimonial: "thanks sorted out the problem took your advice and looked on the control panel changed in the advanced settings section. working ok once again. top "
bhaughee
Bill Haughee
  • 17 Answers
SOURCE: My HP Mini touch pad is locked up
on the new hp mini - you double tap the touchpad indicator (upper left) to toggle the touchpad on & off
Posted on Feb 28, 2010
dgsturt
  • 1705 Answers
SOURCE: How do I unlock the touch pad on my HP mini
I'm not sure what you operating system is but I'd suggest you go to your Control Panel and look for Touch pad and look at the settings there, If there's no Touchpad listed have a look in the Mouse settings.
Posted on May 11, 2010
How to turn the touchpad on and of?
IF IT IS A NEW HP LAPTOP LOOK FOR A BUMP IN THE LEFT SIDE TOP CORNER OF TOUCH PAD ( MOUSE PAD ) DOUBLE TAP ON THAT AREA THEN U WILL NOTICE A LED LIGHT GLOWING NEAR TO THAT...THEN TOUCH PAD IS DISABLED,DOUBLE TAP ON THAT BUMP TO ENABLE TOUCH PAD
Jan 07, 2014 | HP Computers & Internet
Can't right or left click on inspirion 1501, touchpad is fine.
It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
Sep 21, 2011 | Dell Inspiron 1501 Notebook
My hp 4520s probook's mouse pad got locked accidentally, and it's not unlocking by double tapping on the light button on the mouse pad. please help me with this asap.
First, try double tapping the light again. You may have just mis-tapped.
Next try restarting the laptop. Certain laptops re-enable the track pad on restart so long as a USB mouse isn't connected.
If that fails, navigate to the Mouse Settings on your PC and re-enable it there. If you have a USB mouse you can use that. If not, you can use the keyboard. Windows Key will launch the Start Menu, arrow keys can highlight options, Enter will click on them, Control+Tab and Control+Shift+Tab will switch tabs (in a window that has tabs).
In Windows XP and 7 (and probably Vista), Mouse Settings is located at Control Panel > Mouse > Settings.
Mar 21, 2011 | HEWLETT-PACKARD ProBook 4520s
My oven beeps sometimes after use there is no code showing when this happens. the beeping can last for 15 min. sometimes.
most likely you have a bad touch pad the unit has a faulty kep on the touch pad and is going to require a new touch pad...you may be able to turn the power off at the breaker for a few minutes and while off run your hand over the touch pad buttons firmly ..you may luck out and free the stuck one up but most likely you are going to need a new touch pad with the ribbon cable conection...
Jan 05, 2011 | Thermador CM302U Electric Double Oven
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
How do you highlight with a touchpad
With most touchpads you hold down the left mouse button to select then move the cursor with the other hand by pressing a finger on the touchpad and dragging it. Be sure your touch pad is not disabled - usually a button near it with an indicator LED.
Dec 12, 2009 | Toshiba Satellite A505-S6970 Notebook
My HP Mini touch pad is locked up. There's a red light right above the touch pad that is usually white.
Oct 30, 2009 | HP 2133 Mini-Note Notebook
DELL 1501 TOUCH PAD BUTTONS DO NOT WORK AT ALL. HELP.
This could be a hardware or software (windows) problem.
If it is hardware it could be as simple as the connector ribbon inside is loose or that the touch-pad unit is failing. A replacement is $30-$80 plus labour.
I've seen a few of these where the problem is windows acting up. Since you have tried the drivers and they didn't fix it what you can try is go to control panel - system - hardware - device manager - mice and other pointing devices
Open that and select and then delete the pointing device or mouse shown. Then reboot. Windows is now forced to detect the touchpad hardware and reinstall the drivers. That usually does the trick unless it is hardware caused.
Now the tricky bit. Once you delete the mouse you will have to close and reboot using only your keyboard. You need windows to reboot normally, you can't just pull the power cord. To do this use ALT-F4. Hold down the ALT key and press the F4 that will close the windows until you get back to the windows desktop where it will close down windows. When you start the computer again your mouse will be detected and will work again. What we won't know is if that is enough to reset things and get your buttons working until you try this. You can try this a few times but generally if the drivers are right and you have done this then its time to replace the touch-pad.
Aug 17, 2009 | Dell Inspiron 1501 Notebook
Synaptics touch pad, double tap not working
look in the sys tray, (lower left of screen) one of the icons will be concerned with the touch pad. you can turn on and of the double tap here. Sounds like yours is switched off.
Nov 04, 2008 | Logitech V220 Mouse
HP Compaq Presario CQ50-110US Laptop Logo
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
