A very simple solution to r epairing all by yourself is getting help from handbooks, they're very detailed and complete in every way so for me it was my best source to repair
one of the top sites for this is https://big-manuals.com/
while charging, the led is flashing, when charged, the light burns constantly.
A charge should be ready after 4 or max 5 hours. If it takes longer, you have to fear the better is not longer usable.
Although the manuals nothing says about flashing red light on charger, my best guess is the battery is defect.
Try to remove the battery several times and start the charging again and again. But when after a few attempts the LED starts flashing again, you better buy a new battery. When you don't use the camera for a longer period, make it a habit, to charge the battery every 3 months or so.
Charles, The battery turns on steadily or blinks to indicate battery charge status. If the computer is connected to an electrical outlet, the light operates as follows:
Solid blue - The battery is charging.
Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
Off - The battery is adequately charged, or the computer is
turned off.
Flashing orange - The battery charge is low.
Solid orange - The battery charge is critically low
Thank You, Dell-Jesse L Dell Social Media and Communities
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging. posted on Feb 25, 2009
abeales
If
you have windows set to do automatic updates, you most likely had a
windows update installed that caused this conflict with Win Media
Player 11. No fix has been posted by Microsoft yet, so the only
workaround is to Uninstall/Rollback Windows Media Player 11. Goto
<Control Panel<Add/Remove Programs and remove Windows Media
Player 11. Follow prompts, restart computer when prompted to. Also
uninstall Windows Media Player 11 Runtime application following same
procedure above.
This will roll your Windows Media Player back to version 10 or 9,
whichever you had installed prior to version 11. You will need to
re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You
probably need to upgrade your firmware at this point, follow the
instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative
for the screwed up hotfixes that Microsoft puts out on a regular basi
I just called Verizon Wireless who said that the phone may need to be charged completely for a few hours. Try taking the battery out and putting it back on as well.
When you say charge light, was that the battery led light that you were referring to or the power button?
If it is the battery led light, try this:
Try to power on your laptop without the battery in your laptop.
take out the battery and just use the ac adapter, if it works fine then there could be a problem with your battery.
If is the power button that is flashing orange, then try to power cycle laptop.
turn off laptop.
take out the battery and the ac adapter.
then while those are out, you hold down power button for atleast 10-15 seconds.
put back the power source and check the led again.
The charge light flashing orange-orange-orange-green....-orange-orange-orange-green.... usually means the battery has reached the end of its life and now it needs replacing.
There are three ways to test your battery:
1) If the battery has a button on the bottom of it and a row of 5 leds, then push AND HOLD the button for 5 seconds. The LEDs should all turn OFF, then turn back on showing a pattern. If all five LEDs turn on, the battery is dead.
2) Open the Dell Quickset application (doubleclick it in system tray), go to Battery Meter, go to the battery health tab, and pick your battery. It should tell you there if the battery is healthy or not.
3) Reboot your computer and go into the bios. Pick the Battery tab in the bios. It will list the battery health there.
