Question about Toshiba TP50G90 50" Rear Projection Television
Toshiba TP50G90, makes a loud popping sound then shuts off. red light flashes
Loud popping sound, then shuts off, red light flashes. most of the time I can unplug it for a minute or two and when I turn it back on it works for sometimes a couple of weeks. Then it starts all over again. This morning it shuts down everytime I turn it on. Light still flashing until I unplug it.
Posted by lisa richey on
matt
  • Toshiba Master
  • 1,648 Answers
It sounds like its over heating.clean all the fans ,put new artic paste on the cpu
Posted on Jan 25, 2018
5 Related Answers
Anonymous
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
Vista Electronics
  • 1694 Answers
SOURCE: power problem
1)all TV's I service get the chassis pulled for good visual inspection and soldering any/all suspect connections,esp. any
active device mounted to a heatsink.
2)Check horiz drive circuit for weak capacitor.
3)Let me know if you are still on it.....T.
Posted on Oct 23, 2007
Anonymous
  • 110 Answers
SOURCE: TV wont turn on
Hiya only1gal! The issue you're experiencing could be caused by either the convergence ic's or the power supply. Either part will cost about $400 to repair. Sorry for the bad news, and good luck!
Posted on Feb 28, 2008
Anonymous
  • 668 Answers
SOURCE: Toshiba TP55G60 shuts down and red light blinks
Check the powersupply for loose solder conncetions. Especially in the protect circuit.
There is a white waffer looking IC that has been known for the pins to pop open from the
high frequency output of the power supply.
The Powersupply is on the right side and pretty easy to tell. Please use caution when
working on this set because the caps in the powersupply can hold a good charge. If you have any doubts about doing it yourself, call a professional and hopefully the pain in the pocket won't overcome the pain threshold.
Good Luck,
Skyassoc
Posted on Jun 17, 2009
Chi Chu
  • 8457 Answers
SOURCE: my toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Posted on Oct 20, 2009
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
Popping sound
Check for any external shorting of the speaker wires. Check for kinks or cuts in the cable that feeds the speakers. Also check the posts or socket at the back of the speakers for damage or wiring shorting out. Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
Sep 22, 2017 | JVC Mx-kc38 220w Compact Component Audio...
The tv made a pop sound and now it wont turn on ans both green and red buttons are flashing ..please help
I had the same problem guys! This is what I did:
My T.V. wouldn't turn on. The standby light was flashing six times, then four, then seven...I called Sony and they told me to unplug it for a couple of minutes, then try it again...didn't work....BUT, I have found a solution:
Try unpluging your T.V. for 4 hours+, then turn it back on. Worked for me! It's called a "hard reset" by sony. I had my T.V. unplugged for the whole day though.
Aug 11, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Stove cutoff after loud popping sound
The element burnt in to and arced which is the loud noice you heard red flash of light. It probably tripped the breaker at the electrical panel. Don't turn it back on until someone checks the element and replaces it.
May 28, 2009 | Kitchen Ranges
I bought A 65" Mits and had it two days approx. 2hrs. of run time
check the lamp. it sounds like it failed. you will probably see the broken glass inside the lamp housing
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV made a loud pop
hi,
sounds like a popped power capacitor, its going to have to go to the shop most likely around 100.00 repair. taking the back off yearly and airdusting them helps, especially if you have a smoker in the house. caution high voltage present even when off, the heavy single red wire going to the tube is high voltage be careful.
J
Jul 11, 2008 | JVC AV-32FA44 32" TV
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
Televison & Video Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
