Question about HP Compaq Presario CQ50-110US Laptop
My light blinks three times and nothing happens?
Posted by Bernie Cutlip on
joecoolvette
  • HP Master
  • 5,660 Answers
1) I would like you to remove ALL power to the Notebook PC. Remove the AC adapter (Charger), and Battery.
2) Place a towel on the table you'll be working on. Place the laptop upside down on the towel. (Bottom facing up. Towel helps to protect table surface, and laptop finish )
3) Looking at the bottom of the laptop, with the Battery Compartment facing away from you, the Memory Module Compartment access cover, is in the middle. (Rectangular cover with a vent in it. The larger Harddrive Bay access cover is below it )
Loosen the two Philips head screws in the cover. Lift the cover on the same side as the screws. Lift the cover at approximately a 45 degree angle, when removing. There are small plastic tabs formed out of the cover, on the opposite side of the screws. These may be easily broken off, if the cover is lifted straight up.
The spring-like retaining clips hold the ram memory module in place.
One on each end. These are gently spread to release the ram memory module.
When released the ram memory module will pop-up slightly.
The ram memory module should be removed, at NO more than a 45 degree angle.
Bringing the ram memory module straight up when removing, will bend the contact pins in the ram memory slot, and damage the gold plated contact pins on the ram memory module.
The gold plated contact pins develop a type of 'corrosion', after time.
This leads to a poor contact with the ram memory module to the ram memory slot.
Advise use a pencil eraser to clean the gold plated contact pins.
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
If using an eraser on the end of a pencil, and not a solid eraser, refrain from letting the metal band touch the contact pins.
Handle the ram memory module by the Body.
The Body is all of the ram memory module, Except the contact pins.
The Body is coated with a see-through protective plastic. Helps shield the ram memory module from Static. (Electricity)
The bottom of the ram memory module is the contact pins.
Start at the top of each contact pin with the eraser, and stroke down.
Do this for All contact pins. Both sides of the ram module.
Doesn't take much rubbing to clean the contact pin. When finished use air to remove the eraser dust. You can use a can of compressed air for computers, if available, or air pressure from your mouth will be sufficient.
Reinstall the ram memory module/s. Reinstall the Memory Module
Compartment cover. Reinstall the Battery. Turn the laptop over on a Hard surface, (No towel), and attach the AC adapter. Plug AC adapter into power.
Wait 1 minute. Turn the laptop on.
Still no joy? Post back in a Comment.
Regards,
joecoolvette
Posted on Nov 27, 2011
Green light blinks three times but T.V won't power on
Power supply probably fried. You will have to take the TV apart to test.
Jun 23, 2012 | Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
When we turn the power on, a little light blinks 3 times.
operating system not loading. start w out usbs occupied. if nothing in usb then start in safe mode.if u cant start in safe mode try w operating system disk in. if that fails test real time clock battery. if that fails find way to reformat hard drive. or get another.if u got the pc this way this is a bad sign
Apr 25, 2010 | HP Pavilion dv9000z Notebook
RCA HD56WW66 green light blinks three times then nothing
install the RCA repair kit called the CP50, CP120 and CP114 repair kit from www.tvrepairworld.com the kit also contains the instructions on Cd
Apr 14, 2010 | RCA HD56W66 56" HDTV
I try to turn on the tv and the green light just blinks, nothing happens. After a few minutes it shuts off and the red light blinks two times and pauses. The red light blinks until I disconect from the...
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Dec 06, 2009 | Panasonic PT-56LCZ70 56" HDTV
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
I'm having a problem with my Panasonic PT-53wx52
Oct 30, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Blinking Lights, Computer Wont Boot
If it's blinking 9 times then it's likely telling you one or more of the RAM sticks are in need of replacement. To check these, remove the laptops power cord and battery, then locate and remove, the cover for the RAM. Remove one chip at a time and try booting the laptop.
May 25, 2008 | Dell Inspiron 6000 Notebook
Blank screen, no sound
If ti blinks three times, then it may be an issue with the flyback transformer. It's called "three strikes"...it tries three times to come on, and after that enters a safety shutdown mode to protect the TV. Might need to have a professional shop take a look at it.
May 02, 2007 | Durabrand DWT1905 TV
HP Compaq Presario CQ50-110US Laptop Logo
44 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
