Question about HP Compaq Presario CQ50-110US Laptop
My hp g50 will not turn on.Can you help me? - HP Compaq Presario CQ50-110US Laptop
Posted by Bernie Cutlip on
Brian Sullivan
  • HP Master
  • 27,725 Answers
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
also check your computer ram modules to make sure they are dust free and securely seated and the cmos battery has charge
hope this helps you
Posted on Nov 27, 2011
HP G50-111NR went dead while booting up. Now it will not turn on. Lighting bolt blinks three times when power botton pushed.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
May 31, 2011 | HP Pavillion G50-111NR Notebook
Wireless capability shut off. what function key combo do I press to restore? It's a HP G50 Notebook
There is wireless switch - either under the screen or on the front of the computer. Find it and check position of the switch. Usually, there is light next to it. Good luck!
Mar 29, 2011 | HP Pavillion G50-111NR Notebook
Warranty?
contact hp support on line
Apr 10, 2010 | HP Pavillion G50-111NR Notebook
HP G50 laptop,problem with apostrophe key
It seems likely that you touched the CTRL key while pressing the apostrophe key, which creates a shortcut to an accented letter eg CTRL+',e will give ?.
Try Ctrl + e again to see if it goes away..cheers
Jan 16, 2018 | HP Computers & Internet
Panasonic g50 unlock codes
here is a link hope it helped
http://www.foneszone.co.uk/unlock/how_to/Panasonic/G50.php
Sep 05, 2009 | Panasonic G50 Cellular Phone
Having a problem connecting HP G50 laptop to TV
You will have to select the input for this connection.
Sep 03, 2009 | Panasonic TH-50PX75U Plasma HDTV
HP Compaq Presario CQ50-110US Laptop Logo
73 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
