Lorraine Armstrong Posted on Nov 27, 2011
Printer is offline
My printer just won't print and the message is Printer offline
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 27, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
102
Points
Did you check the connection of both the USB and the power? Those are the two most common responses for that error.
More information might be needed if problem persists.
On a mac, my brother hl2240 printer says it's offline and won't print
If your are facing brother printer offline error so you can follow this blog for fix brother printer offline error. Maybe it could help you but follow the instruction as given.
SOURCE: https://bit.ly/3ivebK5
When i print from hp deskjet D1560 it dose not print. It automatically shows offline when i print even though it is not offline. And it dose not print self test page also. pls give an instant...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
1helpful
2answers
When I try to print I get the message " Printer
Check the following steps to fix printer offline error :
11helpful
2answers
Print status: error - offline what does this mean? I have a PSC 2355 all-in-one
Printer status offline means that, the printer driver and the application has been installed, but the printer and it spooler services are idle
To resolve this issue:
Goto control panel, click on printers and faxes, a window will open showing you all the printers you have or have had. The current printer will have a checked mark. Highlight it and right click, you will see printer offline in the box, click it. That will turn the printer online and you can print.
1helpful
2answers
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
k24674
ADMIN Andrew
ADMIN Andrew
