Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
peter j perez Posted on Nov 27, 2011
Not dispensing ice or chrusing - Frigidaire FRS-26DR7D Side by Side Refrigerator
Daniel Kane
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Sep 13, 2013
Daniel Kane
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
1263
Points
8
Not to be glib, but one night my wife accidentally LOCKED the dispenser trying to turn on the light (front panel)...there is also a switch to turn off the dispenser inside my Kenmore...I believe in the KISS principle, check the simple stuff first. I assume it is making ice just not dispensing.
2answers
Water dispenser works ice maker works but no ice through dispenser
If your refrigerator's ice maker is working, but no ice is dispensing through the dispenser, there are a few possible causes and troubleshooting steps you can try:
  1. Check the ice chute: Make sure the ice chute is clear of any ice obstructions. Sometimes, ice can get stuck in the chute, blocking the flow of ice to the dispenser. Use a plastic utensil or a straw to clear any ice buildup or debris in the chute.
  2. Inspect the dispenser mechanism: Open the dispenser area and check if any part of the mechanism is obstructed or damaged. Look for any ice blockages or misaligned parts that may be preventing ice from being dispensed properly. Clean or repair any issues you identify.
  3. Verify the dispenser solenoid: The ice dispenser is usually operated by a solenoid that controls the release of ice from the ice maker. Ensure the solenoid is functioning correctly by listening for a clicking sound when you press the ice dispenser paddle. If you don't hear a click, the solenoid may be faulty and require replacement.
  4. Check the dispenser motor: The dispenser motor is responsible for activating the auger that pushes ice through the chute. If the motor is not functioning properly, it may need to be replaced. Test the motor by activating the ice dispenser and listening for any humming or buzzing sounds. If you hear the sound but the auger is not turning, the motor may be faulty.
  5. Inspect the ice bucket: Ensure that the ice bucket is properly installed and seated in the correct position. Sometimes, if the bucket is not aligned correctly, it can prevent ice from flowing through the dispenser. Remove the ice bucket and reposition it securely.
  6. Check the water supply: Make sure the refrigerator has a steady water supply. If the water supply is interrupted or the water filter is clogged, it can affect the ice production and dispenser functionality. Check the water line and replace the water filter if necessary
Ice dispenser on refrigerator has quit dispensing. ice maker and water dispenser still work. fuse, switch? What do I need to do?
https://www.youtube.com/watch?v=p9GjSqi6eY4
https://www.google.com/search?source=hp&ei=yj52Xrn4O9aGjLsPjY2MkAY&q=Ice+dispenser+on+refrigerator+has+quit+dispensing.+ice+maker+and+water+dispenser+still+work.+fuse%2C+switch%3F+What+do+I+need+to+do%3F&oq=Ice+dispenser+on+refrigerator+has+quit+dispensing.+ice+maker+and+water+dispenser+still+work.+fuse%2C+switch%3F+What+do+I+need+to+do%3F&gs_l=psy-ab.3..0i362i308i154i357l6.3892.3892..4963...0.0..0.280.280.2-1......0....2j1..gws-wiz.....6.KpTP5CQ-W1Y&ved=0ahUKEwi5hZO9_KvoAhVWA2MBHY0GA2IQ4dUDCAU&uact=5#kpvalbx=_8UF2Xqv7BqLHxgOu8YKYDw57
Ice not dispensing through the door and I dont hear a motor
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Question: Kenmore Refrigerator Will Not Dispense Ice Through the Door. My Kenmore... I don't hear the motor or the crushed ice. What do I do? I have a nearly ...
Ice maker is not dispensing - Checking auger motor & ice ...
? 5:33
https://www.youtube.com/watch?v=Uk83V-fA8Pk
Jul 1, 2013 - Uploaded by ApplianceVideo.com
Ice maker is not dispensing - Checking auger motor & icebucket - Maytag, Whirlpool MSD2550VE502 ... Don't like this video? Sign in to ... The Geek - Maytag French Door IceMaker Replacement - Duration: 25:28.
Ice Dispenser Repair Guide - Appliance Repair Guide
www.appliance-repair-it.com/ice-dispenser.html
Ice dispenser not dropping ice using dispenser knob
If you can hear the auger motor turn, you may have a large chunk of ice in the hopper.
Ice dispenser wont dispense ice
sounds like a problem with a belt or something or you cango here http://www.theelectricdiscounter.com.au/new/enquiry.asp and ring the nomber
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
2helpful
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
2helpful
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
ice bucket?
bin.
ice?
2helpful
2answers
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
