I have an LG small LCD tv in the bedroom which, up until recently, was receiving a signal from our living room tv (running via a SKY HD+ box) via coax cable, enabling me to watch whatever was being watched in the living room. This has since ceased to work. I've tried plugging another portable tv in the bedroom using the coax cable and it works fine. I'm assuming therefore that the problem lies somehow with the aerial socket on the LG TV? anyone got any advice or solutions to this problem?
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
SOURCE: Aerial socket
Hi..
As I have seen the full specs of your LCD monitor I don't have seen any aerial port or a socket features with your monitor it only supported by a DVI-D, VGA signal input, that's means that it has no aerial socket.
Hope it helps...
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
SOURCE: Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
SOURCE: Stopped receiving sky on second tv - does my samsung need a reset
I install a lot of magic eyes etc.
You have checked that the magic eye lights up when it is connected directly into the sky box. So your eye is working correctly.
the next step I would take is with your sky remote in your main room. press SERVICES, 4, 0,1, SELECT go to RF settings and check the rf channel and make sure the power is on. Take a mental note of the channel number.
Now go into the room where the link is feeding. Turn on the TV and go to channel number 6 press your MENU button and then go down to setup. go across to manual install and then down to the channel number type in what you retrieved from you box ie rf channel and then type it in and STORE.
If you go into your main room and just put the normal tv guide on ie blue screen. then check that your getting the sky into the other room. IF you are then great it just needed tuning in. IF not I would remake the coax connectors. as there may be a bit of copper braid touching the centre core. once this is done your sky should be on all you need to do now is put the eye back on. Once you have done this the red light should appear on your magic eye. if not go to your main box and follow the first instructions I gave you and turn the power off on the RF and then save and then go back in and turn it back on and save.
Hope this sorts out your problem
Cheers
Little Dish Fitter
SOURCE: Water leak from inside the tv aerial through the pin connector
its most likely a leak in the roof following the wire down to the tv this could be a very big problem as any wood on the way to the tv has a chance to rapidly rot and create larger voids for air to get through you will want to send someone up to the roof to check where the line comes in and caulk the hell out of it
Robb
Freeview are modifying their frequencies and multiplexes - retune your tv , if that fails do a factory reset then retune! Its 90% of the time due to an aerial/signal reception problem. As freeview are currently modifying broadcast frequencies its more than likely that!
The LG tv's are very sensitive to aerial signal power - if it doesnt get the signal it greys out the icon - in your case it does sound like the i/o board may have a fault on the aerial input though if your other tv is working - your other tv may also not be as sensitive as the LG HOWEVER - BOTH MY lg TV'S HAVE GONE AT THE SAME TIME AND ITS DEFINITELY FREEVIEW SIGNAL AS gLASGOW WAS CHANGED LASDT MONTH AND THATS WHEN THE ISSUE BEGAN!
