Question about Vulcan EF3 Deep Fryer
How to remove and clean burners of soot - Vulcan EF3 Deep Fryer
Posted by lamar on
Susan Bennett
    Scholar:
    New Friend:
  • 99 Answers
You can purchase deep fat fryer cleaning solutions in a powder form or liquid....we sell them and other companies do too. The key is to boil your product, along with water in the fryer, using a L shaped brush to add in the cleaning process. You may need to do this a couple of times, if your fryer is really bad. If you boil it out, drain it and it's still really cruddy, then use a green pad and scrub what you can manually, then fill it back up, use whatever product you desire, boil it out again, using your L brush too. That will help clean out the drain hole where you drain the grease out, as well as the burners too. This is not an easy job, so if you think 15 or 20 minutes will do it, it won't... It's tough to clean restaurant equipment, as it's used normally 24/7 and not taken care of very well normally. Spills are burnt on, nothing is ever wiped up, grease spills over the sides of the fryer, and the crumbs in the bottom are burnt over and over, as some people don't strain their grease, just using it until it becomes unuseable... It's a tough job, but one we do quite often, and you just have to put in some elbow grease, use your cleaners, along w/the boil out method, a green pad or 2 or 3, and when you are satisfied and done.... Be super sure to rinse all the chemicals out of the frypot before you add any oil to it. Leaving ANY soap in the bottom of the frypot will help to break down your oil and spoil it way before it should, and that's expensive to replace over and over. Keep your temperature down to 325 degrees and that will help you save your oil as well. If you want to really extend your oil, buy and use a additive like Miroil. This is a oil additive that is used to extend the life of your oil, on a daily basis, sometimes twice a day, depending on your hours of operation/business. This additive , along with keeping your temp at 325, straining your oil, and rinsing your pot out well before adding oil will extend your oil so well, that you will never dump a whole vat of grease again....You will get a formula that will tell you how much grease to pull each day and you will replace that amount with new oil....If you have 2 fryers or 3, you would pull oil from your appetizer fryer and put it in the fish fryer, dumping that oil, whatever the measure is, like 3 cups or whatever. The idea is that your appetizer fryer has the lighter cooking foods in it and the fresher oil. The fish fryer can handle the older oil a bit better. All fryer foods will look/taste/ much better all week long, without your foods getting darker as the week goes on... Your foods will also absorb less oil, if you keep that temperature down to 325 instead of 350 or higher. That higher temp also helps to burn your oil up quicker, so keep it down....
I've seen this product work, and every customer I ever sold it to, never stopped using it once they started, and the cost is under a dollar a day.... Your savings are huge, as oil is one of your most expensive costs in the food industry. If you need a place to buy the additive or the fryer clean out products or the L brush, we sell all of it and can ship directly to you. Restaurant Equipment Outlet, Cincinnati, OH 888-542-5959.
Happy Frying...
Posted on Nov 28, 2011
How do i clean the burner in my smoker box its sooting everything up
first remove burner , clean all air ports on burner check burner is not split . blow burner out with air line or vac inside could be blocked . clean off all soot . replace burners and see how flame looks should be nice and blue not yellow .
Jun 30, 2018 | Grilling
Soot produced by propane heating stove
If it is still producing soot two problems blocked burners burning yellow causes soot , or blocked injectors, or pressure to burners is wrong needs seting to correct pressure
Feb 07, 2013 | Heating & Cooling
Got a build up of soot want to clean the mechanics/baffels etc got a manual on that
If you have build up of soot you need a service and a gas fitter to do it .
Jun 15, 2012 | Pitco Frialator SG14 Deep Fryer
Black soot every were how do i clean it and what with
Well, Boat Bob, you can clean the soot off by using a Shop Vac with a brush attachment on the hose. That will take off the biggest portion of it. Then you can clean the remainder of the outside with a damp cloth, but be sure to dry the cabinet afterward. Remove the screws the are holding the face of the of the cabinet on and proceed to clean all of the interior of the heater cabinet fire, with the Shop Vac , being sure to vacuum the burner(s) thoroughly, as well as the pilot assembly and all the mechanical 's. What soot isn't removed with shop vac, should be removed with a DRY cloth. Then use a can of compressed air with a straw nozzle (like you clean your computer with) to blow out the pilot and all around the pilot assembly.
For the remaining soot on walls, ceilings, furniture, etc. Gently vacuuming is the best way to remove the lion' share of the soot. Then, if necessary, the walls and ceiling can be washed with a diluted solution of Simple Green and water. Clean small areas at a time.
After that, you need to turn your attention, as to why the heater sooted? Several things come to mind ... No annual professional cleaning and service; Incomplete combustion; Vent pipe partially obstructed; Low gas pressure; Clogged burner(s), Obstructed air intake.
If you'd like further information, here is a link to your Owners Manual, which will help you to Troubleshoot the heater. http://www.empirecomfort.com/EMPIRECOMFORT/pdf2009/manuals/12433-10-0109DV.pdf
Hope this helped you to answer your questions.
Mar 24, 2011 | Empire DV-215 Direct Vent Natural Gas...
Burner is sooting when grilling with soot on the meat
clean the burner and gas orffice check to see if burner is split if so change it
May 13, 2010 | Grilling
Soot build up
Flame is Orange? If so, propane is "choked", not enough air. Remove burners, clean each burner hole with a same size metal dowel (coat hanger works well) flush out inside of burner with garden hose, hi pressure air through all holes to dry. Replace burners ONLY after also cleaning chambers and chimney (garden hose and long brush). Do not forget to clean pilot light area too.
Most Imperials are pre-set air intake. Check gas pressure if able, 3" NG, 10" LPG. Good Luck
May 12, 2010 | Imperial IFS40 Deep Fryer
I have an Enerco Group 30,000-80,000 BTU heater
HI clean the burner , and the air ports on the burner clean the injector remove all trace of soot and dust in needs a good clean see if that works also clean the pilot
Feb 03, 2010 | Heating & Cooling
Soot coming from flu
Remove the burners and clean the burner orfices and baffles,also check the vent cap on the pressure regulator that sits on the back of the fryer.Let me know.
May 14, 2009 | Pitco Frialator 35C Deep Fryer
Vulcan EF3 Deep Fryer Logo
208 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Lawrence Oravetz
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
