Because there is no detailed information about your iPod, gonna show you every solution
1. If you have your iPod backed up to iTunes or iCloud, you can recover deleted text messages from the backup; however we all know if you directly restore iPod with iTunes/ iCloud backup, it will erase the existed data.
2. If you didn't backup your iPod, it seems there is no way to get messages back. Actually the deleted messages are just missing visually, and it still exists on the iPhone hardware. We can bring them back with some professional software, such as PhoneRescue. I once use PhoneRescue to recover deleted messages from iPod touch successfuly. The big point is PhoneRescue also supports recovering data from iTunes/iCloud selectively, which means you don't have to recover the whole backup to device; and it will not erase your existed data.
With these two methods, you can totally recover your deleted text messages.
https://www.imobie.com/support/how-to-recover-deleted-messages-on-ipod-touch.htm
If you have created a backup of iTunes for your iPod, you will be able to recover text messages from iPod with ease. Only 3 simple steps are needed.
This is the fastest way to restore deleted text messages from iPod.
http://www.leawo.org/tutorial/how-to-recover-deleted-imessages-from-ipad-air-2.html
If you backed up after the messages were sent, then try restoring from backup. Make sure that you turn off automatic syncing first before you connect. Go to iTunes>Preferences>Devices and check the box that says Prevent iPod...
Connect iPod to computer, and then open "Computer", iPod should show as
a drive letter there. If not, please follow these instructions: In
iTunes, right click on your iPod and select "iPod Options". Under the
"iPod " tab, make a tick in "Enable Disk Use". Click OK. Unplug your
iPod, then replug.
Now follow steps below
Step1: Download this data recovery software, then install and launch it in Windows machine correctly.
http://www.asoftech.com/adr/
Step2: Sync your iPod with computer.Then you should see it shows as a drive letter in 'My Computer' like H:/.
Step3: Select iPod drive letter and then click "Next", you will find all your lost files in the lists.
Step4: After the automatic scanning, it's time to finish all the steps by clicking "Recover" easily to Recover your files!
Hello, tajuanamcelr! You can retrieve your lost text messages with An iPod Data Recovery tool. Learn more here: http://www.squidoo.com/recover-data-ipod Best wishes!
