Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
Picture shattered with black and colorful lines, is it fixable?
Anonymous
    Novelist:
  • 181 Answers
Hello!
unless the display panel has been physically damaged, which it seems by your description, replacing t-con board or trying to reconnect panel's ribbon cables first, may solve the problem. otherwise, the cost of new panel voids any reasonable repair.
Good luck,
Alex.
Posted on Feb 01, 2012
2helpful
Samsung HLR5668WTV went black, replaced LAMP. Turned TV on. No picture but now there is a humming noise. TV try's to turn on 2 or 3 times then doesn't and all 2 indicators lights are blinking.
If the noise is a high pitched whine or even a grinding sound you may have a bad color wheel.
These fail quite often in these sets although it is unusual for a lamp to be associated with it. Put old lamp back and see if same problem. (unless old lamp is shattered)
If it is the color wheel I can tell you how to look at it to see if shattered without taking the set completely apart.
See attached photo of typical color wheel.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Rainbow lines and no picture
NEW YSUS AND BUFFER BOARDS ARE NOW NEEDED THE YSUS IS THE BIG BOARD IN THERE VERY LEFT HAND SIDE ONCE BACK IS OFF BIG BOARD WITH 1 BIG HEATSINK,, THAT AND THE BUFFER BOARD PUSHES INTO THAT WITH TWO BLACK CONNECTION TO THE YSUS REMOVE BOTH BUFFER IS FIDDLEY,,NEED TO REMOVE 4 RIBBON CABLES ATTACHED TO THE SCREEN B4 HAND,,
6871QYH053B IS YSUS MODEL BUFFER U WILL ALSO FIND ON EBAY.
I have vertical color lines and horizontal black lines in sharp lcd - is this fixable?
By the sound of it, not fixable. LCD assembly usually cost more then a new TV.
Picture is black and white and fleckers. changed
In most cases this is due to the fact that the color wheel has shattered into pieces and will need to be replaced. Replacing the color wheel is not too easy, but if you are technically handy it isn't that tough to replace either. The part number for the color wheel is BP96-00250A and will run between 80-130 dollars for the part.
I have a 35 inch older model.heavier than heck....
this is fixable, normally it is caused by a capacitor or an ic, but it is fixable
1helpful
While watch tv last night heard a crakle and we lost the picture on our samsung dpl tv. We got a new lamp and installed it. There is still no picture.
Sounds like the color wheel has shattered and the sensor is blocked by the peices. If the wheel was not blocked you would have a black and white picture.
3helpful
Black line half way down the center of the screen,about 1.5 inche
There's a 'data control' and/or 'address' problem that's developed. Pixels depend on voltage, control, and data coming too their designated address.
A digital circuit feature called a 'DATA_ADDRESS_ BUS" are responsible for 3 criteria: Delivering voltage, control, and data to each pixel in less than a second.
1) If voltage fails the pixels don't light up. They appear black in color (their 'off 'state)....numerous pixels that don't light up look like a black line. But their actually individual pixels with no voltage.
2) If control fails then all pixels are white in color (their 'on' state). Without control the pixels can't adjust properly to high or low 'state', meaning brightness and dimness. This looks like a white line vertically on the screen.
3) If data fails then the pixels can't adjust to the proper color at the proper time.
This appears as a line that changes color out of sync with the entire picture.
Have a technician look at the pixel address registry circuits. As well as control and linear circuits....the problem is somewhere in there!
1helpful
Black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
3helpful
3answers
I heard a pop and now the projector only shows black and white.
The color wheel has failed in youtr projector. There are 4 pieces of glass in the color wheel which fit togeter in a "pie" formation and they are red, blue, yellow & clear. This wheel is spun by a motor. The glass is glued to the motor's hub, and, when it fails the glass segments are thown off the hub. This gives you a B&W picture because all of the light is allowed to shine through the optics all of the time. Replace the color wheel with Toshiba part no: 23125963. It will be about $65. No soldering is involved, just use care with the ribbon cable to the motor. You will need a no. 2 phillips screwdriver and a set of jeweles screwdrivers to do this.
Stuck on black and white
Hi, this is usually an indication of a shattered color wheel, the only way you can be certain is to take the set all apart and look at the color wheel, looks like a set of prism glass mounted on a fan shaft, if the shaft doesn`t spin or the prism glass comes apart the picture will be black & white, hope this helps, BMW Rider
Top Sony Televison & Video Experts
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
