Question about Omega SeaMaster Watches
Can i change my watche ?
I bought an Omega Seamaster watch no. 90778797, unfortunately after 9 months it started working inaccurately . Since then I've sent it to the service center ( in Iran) 4 times they ve ,also, changed the engine once ,yet it isn't working accurately . what should I do now ? it s still with warranty , can I exchange it in Iran or other countries ? Best regards Honey Heidari p.s. my email address is : [email protected]
Bill Boyd
    Top Expert:
  • Omega Master
  • 53,816 Answers
It is still under warranty
contact the ,manufacturer customer service and ask how to get a refund for the faulty item under warranty
Posted on Jul 10, 2017
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: omega seamaster
sounds like an auto wind watch,you must wear this watch most of the day to keep it wound up.to wind the crown must be pushed all the way in.
Posted on May 04, 2007
Anonymous
  • 125 Answers
SOURCE: Omega Seamaster battery
Well maybe if you use a coupon then the price will be lower.
Posted on Mar 06, 2008
wilbur901
SOURCE: omega seamaster professional chronograph
It requires a service.
Posted on May 25, 2009
Anonymous
  • 183 Answers
SOURCE: Why do the Omega Seamaster watches have a second
This is a helium release valve.
The purpose and function of the helium relief valve is a common point of confusion. It has nothing to do with normal underwater diving. Neither does it have anything to do with the depth rating for a diving watch. Helium does NOT seep into the watch while the watch is in water at any depth!
To put it simply, you can completely ignore a helium relief valve. This feature is not used in any way with any form of normal SCUBA diving or anything else that involves less than a multi-million dollar deep sea exploration project.
SCUBA diving activities normally occur at depths of no more than 120 feet. At 250 feet, air becomes toxic due to changes caused by the high pressures at such depths. For those who do very deep sea research, they often use diving bells, dry dive suits, and other types of very deep ocean exploration vessels. In some of these, a highly helium-saturated atmosphere is used to avoid the air toxicity effect.
The purpose of a helium release valve is for people who wear their watch inside the helium-saturated environment for an extended period. Because helium is the smallest atom, it will seep through the watch's seals under the high air (not water) pressures in this environment. If the watch stays in this environment for an extended time, helium will continue to seep in to the watch until the air pressure inside the watch (initially surface air pressure) equalizes to the air pressure in the environment.
This becomes a problem when the vessel is brought back up and depressurized. The helium which seeped into the watch over a couple of days, cannot seep out any faster. The excess pressure inside the watch needs a way to release faster than it seeped in. It is only in this situation that a watch needs a helium relief valve at all. If a relief valve was not on the watch, the excess pressure would likely escape by pushing the crystal out.
But, unless you are in this exact situation, you should never keep this valve open. While the watch is designed to maintain most of its waterproof abilities even when the valve open, it still serves no purpose and increases risk of damage to the watch to do so.
Posted on Sep 23, 2009
Testimonial: "What a totally great reschearched answer!!! Very informative!!!"
Anonymous
  • 93 Answers
SOURCE: omega automatic seamaster losing time
Most likely your watch needs to be serviced.
Every watch, both mechanical and quartz needs regular service.
When the oils in the watch dry out they get gummy and will work against the gear train. They also stop lubricating and friction builds up causing wear.
Hope this helps,
Ken
Yellowstone Watch Inc
Posted on Oct 05, 2009
1helpful
3answers
May i have information about omega watches?
Top omega watches internet wide free delivery. For Omega watches, quality, creativity and innovation work together. It can make use of the better of materials to style its watches. visit it http://sbwatches.com/
Apr 06, 2014 • Watches
2helpful
Help! i have a misty face on my omega seamaster how can i fix this?
Have you had it serviced recently or the battery changed in a non-authorised jewellers. It looks like your seal has gone. Omega need to be compressed after opening the back.
1helpful
Is an Omega seamaster copy waterproof? (And this is not a Chinese cheap copy either. It appears very convincing.)
Generally it is safe to assume that copies are not waterproof although they be water resistant. Genuine omegas are sealed and compressed which is why a battery change at an authorised dealer (who will end the watch to omega) is approx £40.
Omega automatic seamaster losing time
Hope this helps,
Ken
Changing the Bezel on an Omega Seamaster Planet ocean
I would strongly suggest taking it to an approved Omega dealer so it can be repaired by Omega themselves. This retains your guarantee, reseals the watch and protects your investment in a *fabulous* watch. I have the same watch and I love it. The aftersales care is excellent. You should be well looked after.
2answers
Omega seamaster gmt
what you have to do is that pull the crown to halfway do not pull completely out, if you pull halfway out and then move the crown to clockwise or anti clockwise it will change the date. if you pull completely out then it will change the time.
2answers
Omega seamaster
Time delay
try manually winding it if you can, and see if it still happens. If it does it probably needs to be sent in for service
Watches Logo
Top Omega Watches Experts
Ekse
Jimmy Accardi
Are you an Omega Watch Expert? Answer questions, earn points and help others
