Try holding down your Home Button and your Lock Button at the same time for about 10 seconds or until you see the apple logo. This will restart your phone and should resolve your problem!
I had a similsr problem but with a different model of phone, had to contact the provider as the phone was stuck on 'continually updating' and when it was like that you could do absolutely nothing with it. Call yoiur provider or drop by a kiosk with a knowledgeable attendent. Good Luck
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Something more than likely chipped off/broke from the impact of the drop. Have you tried opening the PSP? *Note - opening your PSP will void your warranty.
It's an electronic device so it would be very difficult if it'll fell in water. first remove its shell and then get a hair dryer and turn it to low. carefully blow dry the insides of your phone. if you are using an iphone it would be best to consult a phone tech.
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall.
ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time.
Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
i gues you have dropped it or it got wet. Bring it to your local telephone shop and ask to clean it. That only cost like 10 dollars and when they put it back together the align the keyboard
Did that and still wont come on. Also tried hooking to usb still nothing.
