Clicked print but it goes to the que and doesnt print
SOURCE: Printer problem
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-2&cc=us&lc=en&dlc=en&product=374568
Go to this page on the HP website and see try running this utility. Does that help?
SOURCE: Dell Laser Printer 1720dn Will
Check that the correct printer is set as default. Also use File Print so that the selected printer is shown rather than using the Print button. If the test pages are being printed from the computer then the communication is working.
SOURCE: Printer not printing documents in que
I have a Dell Photo 926 all in one fax, My print Docs are going in Que. What is the problem with the printer?
SOURCE: I have an hp 5510...Vista documents are in que not printing
Al tratar de accesar a Youtube se me env? a la siguiente leyenda Your browser sent a request that this server could not understand. Size of a request header field exceeds server limit. Cookie: VISITOR_INFO1_LIVE=DHKquoqA4NA; watched_video_id_list_BambinoCorleone=65f1d70558ca0a598d123ebeabdfc2b1WwMAAABzCwAAAGNGdVpvNFFsZ0Za saludos cordiales Guillermo
SOURCE: I can't "delete" a document from the que
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side
window.
On the left side click stop the service and wait forthe process to
stop
Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue
then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler
folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them
depending apon how many print jobs you submitted. You will have to
resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
