Question about Krups Small Appliances Espresso Machine
Coffea maker how mutch water do i put in the water tank it keeps flooding
Posted by milenko simic on
Ross Keen
  • Krups Master
  • 1,364 Answers
There is something wrong, if everything was ok you could fill the tank to the handle without flooding.
Posted on Mar 08, 2015
1 Related Answer
mirran
Mirko Blas
  • 515 Answers
SOURCE: Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Posted on Jul 10, 2008
Watersoftener salt tank keeps flooding
Sounds as if the head has a valve sticking, Need an overhaul kit that has new paddle valves with screen and injector also. Unplug unit, put into by-pass (3 valves above it) then manually rotate cam to depressurize head and tank, follow kit instructions to overhaul, or you may want to call a plumber.
Jan 02, 2014 | Water Reservoir
Eljer toilet bolts rusted causing massive flooding
Turn off the water at the supply (under the toilet, usually).Flush the tank to remove all water from the tank.Disconnect the supply from the tank.Remove bolt caps or bolt covers from where the toilet bolts to the bathroom floor.Remove bolts from the floor flange. When you lift the toilet up, you'll see a metal or plastic flange. If the toilet has been there for a long time the bolts may not pull out of the flange easily. In this case you may have to use a small hacksaw to cut the bolt below the nut.Put newspaper or an old towel on the floor so you can place the old toilet on it. Lift the toilet off the flange.Take the new bowl (assuming this is a two-piece toilet) and turn it upside down. Position the wax ring on the horn of the outlet. Install new solid brass flange bolts, mount them and position them on the centerline on either side of the outlet.Push the bowl down over the bolts and seal the outlet. The wax will squeeze down and seal.Put the new bolts, washers and bolt caps on. You may have to trim the bolt with a hacksaw.Once the bolts are secure, mount the tank.Make sure the gasket between the tank and toilet is in place. Then position the tank on the bowl. Run bolts through the tank and secure. Don't over tighten (the tank can crack).Hook up the water supply line.Connect the supply to the line on the bottom of the tank.Turn on the water.Let the tank fill.Flush once or twice to make sure the water control is properly adjusted.Put the tank lid on.Enjoy.
ford performance chip.
May 25, 2012 | Eljer Home
Anti flood device has activated on my zanussi ZDF231,also there is quite aloud whirring sound ,like a motor struggling to work
The anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water.
Jan 18, 2010 | Dishwashers
It won't run. It has power but won't go thru cycle, won't do anything.
The anti flood activates when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. Nothing else happens until the fault is cleared.
Candy dishwasher 2 program lights keep flashing after program starts then stopas and flashing starts
My candy dishwasher Model No CDI 3015-S retains water in the bottom of the machine at the end of the program. I have checked the filter which is clear so do not know what else to do to clear the problem. Anyone faced this problem or know what might be the cause?
Jan 18, 2010 | Candy 17 in. CS455 Built-in Dishwasher
Flooding carb
the fuel lines were hooked up backwards thanks
Mar 22, 2009 | Ryobi Factory Reconditioned 18" 40cc...
82 aspencade gl 1100 carbs keep flooding? i put them on buddys bike and they run great. so i changed fuel pumps, still flooding? whats left ?
It sounds to me you may have a vacum issue with your tank that is causing to much fuel to get deliverd to the carbs, try checking all the hoses on the tank to me sure they are in the correct place.If so then check the patcock to be sure that it is not allowing to much fuel through.
Mar 10, 2009 | 1982 Honda GL 1100 Aspencade Gold Wing
How to replace a magnesium rod on a John Wood electr. water tank?
You can buy these at any good hardware store- two types- Aluminium and manganese- if you replace and have a odor from water remove and replace with other. Really easy to do. Turn off water pressure to tank . Drain pressure at lowest tap in house. Put hose on drain spiggot of tank and drain off 1-2 gallons .Turn off electrical to tank. Unscrew old with socket- yes socket - do not use a pipe wrench.You will need a power bar Or good solid ratchet to remove and reinstall. Apply a pipe dope or teflon tape to new and srew in place- wrap tape counter clockwise or it will spin off as you turn in place and it will leak. Do not drain tank completely - you require this weight to keep tank from spinning as you remove and reinstall. After tightening slowly put pressure back on system - never shock pipes etc.Just as you do not slam your brakes- don't slam your pipes,Turn power back on after checking for leaks -tighten as required. Double check spiggot after removing hose as dirt can sometime cause a slow leak- monitor all areas for at least 3-5 mins and then check again at end of week. Also know that the lifespan of a tank should max at 15 yrs after that - replace or accept the flood when it happens. Good luck at poat me if you need me. Allen
Nov 26, 2008 | Water Heaters
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Sep 11, 2007 | Vicks V3100 1.2 Gallon Humidifier
Krups Small Appliances Espresso Machine Logo
100 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
