Computers & Internet Logo
k. davidson Posted on Nov 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pc ddr memory what is the difference between high density and low density
When upgrading ram what is better for performance/speed unbuffered/registered high density/low density
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 2,226 Answers
  • Posted on Nov 25, 2011
James Miller
Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447535
Points
2985
You need to check with board to fine what ram works with first.i use what they say to use so no problems later and save money as well ok jim
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
3helpful
2answers
Unit came with 2 256 mem sticks--bought and installed 2 1GB sticks(pc3200,400mhz,84pin,low density,DDR--unit will not boot
The 2 1Gb RAM are either the wrong type or they are incompatible.
Try to use the same brand and speed as the 256 Mb RAM that was installed in your Dell.
3helpful
2answers
Can I put different types of RAM on a motherboard?
Not different types per se, but you may be able to put different speeds.
Type would be like DDR Sdram2_bing.gif, or DDR2 Sdram for example.
Speed is a slang term for Frequency Rate. What frequency rate does the ram memory2_bing.gif module (Stick) operate at.
Example: DDR2 Sdram that has a frequency rate of 667MHz. (PC2-5300) MHz stands for MegaHertz.
Mega = approximately 1 Million. Hertz stands for Cycles per Second.
The above ram memory module operates at 667 Million Cycles per Second.
If you install two ram modules that have a different frequency rate, all the ram memory installed will operate at the slower frequency rate.
(Provided the computer will support more than just one frequency rate)
Have a computer in mind, or is this just a generic question? A what if?
Reply to your recent comment:
If this is in relation to two different manufactures of your ram memory, it shouldn't be a problem.
Where you may get into trouble in this area, is if one ram memory module (Stick) is generic, or low budget, and one ram memory module is a high performance gamer ram memory.
Without knowing the exact manufacturer of your computer, plus the Model name of it, and also knowing the information you have about your ram memory 'sticks', the following information is just generic, or general information.
High performance ram memory may use a higher voltage. Not always, but a good portion of the time.
High performance ram may also use a faster set of ram timings.
It may also have high density DRAM chips, and the chip configuration may be setup differently.
(The black rectangular modules you see on the side of a ram memory 'stick', are DRAM chips)
To explain so far;
SDR Sdram was the typical ram memory for years after SIMM ram memory.
SDR stands for Single Data rate.
Commonly just referred to as Sdram, but in actuality that is erroneous.
(Sdram stands for Synchronous Dynamic Random Access Memory)
Then came DDR Sdram.
Double Data Rate Sdram.
Then DDR2 SDram.
Double Data Rate 2 Sdram.
Then DDR3 Sdram.
Double Data Rate 3 Sdram.
1) http://en.wikipedia.org/wiki/SDRAM
(Anything you see on a Wikipedia page that is in blue, is a link to more information.
To further illustrate this,
2) http://en.wikipedia.org/wiki/DDR_SDRAM )
SDR Sdram specifications were all over the place. What was considered to be a standard for one manufacturer, differed for another manufacturer.
The JEDEC organization was formed.
JEDEC sets the standards for ram memory from DDR Sdram on up.
Voltage for DDR Sdram is 2.5 volts
DDR2 is 1.8 Volts
DDR3 is 1.5 Volts.
Ram manufacturers found that by upping the voltage requirement on high performance ram, the ram could perform, better.
Not true in all cases, as there is high performance ram that operates at the JEDEC standard.
Ram timings were also varied.
Also the chip configuration
Plus the density of the DRAM chip.
Unless it is a really cheap, generic ram module, (Stick), there will be a manufacturers code on the side.
With this code I can tell you the specifications of that ram module.
I can also explain
2helpful
RAM compatibilty
No, DDR 400 will not work. The best thing you can do is call Dell and give them your information. Model number and that kind of information and let them tell you what kind of ram you need. If you put the wrong type of ram in your machine it could cause major damage. There are so many different kinds of memory out there, not to mention high and low denisity. Your machine may use PC2700 high density and if you try to use PC2700 low density it will not work. One other thing that you can try is uninstall a stick of your ram and write down everything on the stickers and then go to some place like kingston memory and use their memory locator to find what you need.
ECS 648FX-A1 can it use high density memory?
The Motherboard limitation are DDR400 = 2GB maximum size per slot
Allthough you can with slower memory DDR333 or DDR266 go to the 3GB memory limit.
Due to the age it will be trail and error on the memory types. You won't necessary get any problems with the high density memory as long as it is good quality memory and you don't exceed the slot memory limit as mentioned above.
I recommend that you download the motherboard manual and read it.
When ordering ram memory for wifes computer
Go with Crucial. I recently used then as the vendor to get memory for a middle school and all of their memory fit with no problems, the shipping was fast and the scanner worked with new and old computers. I would go for the pc2700, although your wife's computer can take both types, faster is better and the higher the number the faster the ram.
Few questions about RAM memory?
Solution:
i)  LOW DENSITY modules have 100% compatiility with ALL systems and ALL chipsets.
    HIGH DENSITY modules only have 10% compatibility
    here compatablity means LOW DENSITY RAM are accepted by all system(100%)  or any make           system.. HIGH DENSITY RAM are accepted by 10% by only some system or computers...
ii) in order to check system performance or amount of Computer RAM usage press the ctrl+alt+del
   simultaneously a new window(window task manager) will appear showing:
    CPU usage: showing the amount of CPU or processor utilized at that particular time.
    PF usage: showing the amount of RAM memory utilized at that particular time.
    Physical Memory: showing Total RAM Memory, Available Ram memory....
iii) baiscally they are two types of RAM they are:
    DDR1:which is older one supported by older system  or older mother boards which is costlier
    DDR2: which is latest one supported by all new system or new mother boards which is less                         costlier
    DDR: double data rated ram......which will send data at a double rate compared to SD RAM
iii) here color doesnt matter, these slots either support DDR1 or DDR2 but not both at a time
    DDR1 has 184 pins or gold plated pinssss... on the edge of the RAM
    DDR2 has 240 pins
    so difference doesnot allow DDR2 to placed in DDR1 motherboards or vice versa...
iv) it does have anything to do with no of chips on the RAM but they only differ whether it is DDR1 OR DDR 2(DDR2 are much faster than DDR1)
NOTE: whatever may the the RAM, each RAM has FSB(called Frequency...) which determines the frequency of rate at which data is tranferred from RAM to processor(CPU)  usually in MHZ such as FSB 300, 400, 200 , 333...................
more the FSB the faster data is transferred to the processor(CPU)
dont worry even RAM with less FSB's work well with the processor....having 1 GB RAM or 2 GB RAM is engouh, it only matters with the speed of CPU ... but not RAM......
1helpful
2answers
New ram
Memory type is the major problem with the 741GX chipset. Very touchy. I used Crucial PC3200 High Density memory to start with (2 x 1 gig Memory), system was lagging even though adjusted settings in bios. whenever a USB device was pluged in, the system would stop responding. Switched to low density memory and no problems since (Ultra PC3200 (2 x 1 gig Memory), and the USB device problem is also solved. I am running WinXP with SP2.
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Grand Canyon Tech
Grand Canyon Tech
