Question about Canon Pixma iP2700 InkJet Photo Printer
An error occured we cannot print a document which the orange light was blink semoustanousely
Posted by jose berigundo on
bernard powell
    New Friend:
Erroe code 6910. flashing orange light
Posted on Sep 24, 2013
ishadi aplus
  • 149 Answers
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
an error occured we cannot print a document which  - 11_27_2011_12_28_37_am.jpg
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
11_2an error occured we cannot print a document which  - 11_27_2011_12_42_07_am.jpgass=
11_27_20an error occured we cannot print a document which  - 11_27_2011_12_46_25_am.jpg
Posted on Nov 27, 2011
  • ishadi aplus
    ishadi aplus Nov 28, 2011
    Sorry, the above solution is to fix the E16 error code (the light blinks 16 times), not the error code E13
  • Gerald Derigo
    Gerald Derigo Oct 10, 2013
    Thanks for good hints. Worked for me and my E13 code.
Dell printer 1250c , printer in Error state
The indicators provide information on the status of the printer and help you locate each problem. Following are the Indicator Status Condition and what they signify.
  • Jam Orange on A paper jam occurred.
  • Orange blinks The rear cover is open.
  • Toner Orange on The specified toner cartridge is empty or not installed when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • Orange blinks The specified toner is low when Dell toner cartridges are used (Non-Dell Toner is set to Off).
  • All toner indicators blink when the printer is in the non-Dell toner mode (Non-Dell Toner is set to On).
  • Error Orange on A fatal error occurred.
  • Orange blinks An error occurred.
  • Ready/Data Green on The printer is ready to print.
  • Green blinks The printer is processing or printing.
  • Orange on The printer is in the power saver mode.
  • Orange blinks The printer is canceling.
  • Start Green on To continue printing, press the (Start) button.
  • Cancel - To cancel the current job or clear the error, press the (Cancel) button.
For detailed information, please click on the link below for Manuals & Documents for the Dell Printer 1250C. Check Chapter 11 - Page 69 to 77.
http://dell.to/1at80gm
Feb 24, 2017 | Dell Office Equipment & Supplies
Will not print copies
This link gives U full information about the control panel errors.. Pl go through it before replacing consumables..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00476294&cc=us&dlc=en&lc=en&product=1146331#N1316
Apr 04, 2014 | HP Photosmart 3180 All-In-One Printer
Flashing orange light
Cannon pixma 3500 Flashing orange light count the blinks for the error,
Mar 17, 2014 | Canon PIXMA iP3500 Printer
Upside down orange light bulb on the right side is blinking. small white logo is also blinking beneath it. It will not print. The print cartridges are new. The are not generic. I have rebooted and un...
When the camera is connected correctly, the Connection light is illuminated. The Connection light blinks green when printing from the camera. If the camera is not PictBridge-compatible or is not in PictBridge mode, the Error light flashes.
Nov 04, 2013 | HP Deskjet 6980 InkJet Photo Printer
Amber light on oki c3300 continues to flash and printer will not print
Here's what the owner's manual has to say:
Error status (Amber, blinking): you cannot continue to use the
printer. Intervention is required to recover from the error. Fatal
errors are irrecoverable and require a service call.
Blinking 1 (2S cycle)
An error has occurred but
printing can continue if you
press the ON LINE or CANCEL
switch.
Blinking 2 (500mS cycle)
An error has occurred. You
need to replace consumables
or remove jammed paper, for
example. The printer then
recovers from the error and
printing becomes possible
again.
Blinking 3 (120mS cycle)
A serious error has occurred.
rebooting or a service call is
required.
The Status Monitor in Windows provides a readable description
of the printer status corresponding to the indications of the
LEDs. In Mac, the printer driver provides status information
once you have sent a document to print. In Windows, if you
have the Status Monitor Preferences set to Pop up on alerts,
this readable message will be presented on screen whenever
an abnormal condition occurs.
There's no further information. Sorry.
Jul 19, 2011 | OKI C3400n Laser Printer
Hello there wondering if you can help me My power light on my Canon ip2000 keeps flashing green/orange and the print queue stops and nothing is happening. I've powered the printer on/off Also have...
Usually means theres a paper jam or your out of paper or some problem is occurring. While that blinking orange is blinking press and hold it for about 5 seconds the printer should stop blinking orange and continue with the print. Also open up your printer to see if there are any documents that are in the print queue. Probably can delete those. Thats my guess as to whats wrong with the printer. Used to have one of those. Nice little printer remember 12 blacks for 12 bucks.
Dec 16, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Document is not printing
Press the feed button. If that doesn't work, turn the printer off, wait a few seconds, and turn it back on again.
Feb 03, 2009 | HP DeskJet 932c InkJet Printer
Says ready, error light blinking, vertical non-print line
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Aug 13, 2008 | Konica Minolta magicolor 2400 Laser...
Canon Pixma iP2700 InkJet Photo Printer Logo
2,730 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
