Hi First you have to check the water valve to see if it has power during the time it should be filling the washer , Set the unit to fill and wash you know where it normally starts filling with water , remove the two wires from the water valve and check to see if you have power going to the valve , you have to eleminate things to find out what the problem is , if you have power then check to see if you have water to the valve, if you have water and you have power but you arent getting water then the water valve is bad , and this will be a cheep easy fix , have a good day
