Hello, I'm getting a F3 error code on my 911-45569690 oven range. Is it the temp. sensor
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
The error code message F3 E0 indicates an open oven sensor circuit. This is the component that regulates the oven temperature.
First disconnect electrical power to the range. Pull the range out & remove the rear panel to the control area. Unplug the 2 violet wires on P3 5-6. You will need to have a meter for testing, set the meter to read ohms (resistance). Place the leads from the multimeter across the 2 violet wires, the meter should read 1080ohms if the sensor is good. If you do not get the correct reading you will need to replace the oven temp sensor.
The oven temp sensor is mounted to the inside of the oven cavity. You will need to remove the lower section of the rear panel to access the sensor connector. Unplug the sensor & slide it back into the oven cavity to remove & replace.
Taken from...
http://www.managemylife.com/mmh/questions/120802-kenmore-range-displaying-e0-f3-error-code
