Question about Xact Communication XTR1 SIRIUS Radio Receiver
Owners mamnual - Xact Communication XTR1 SIRIUS Radio Receiver
Posted by Beth Porter on
NEED DIGRAM OF MOTION DRIVE BELT MURRAY MODEL 40504X92
yOU CAN FIND A PARTS MAMNUAL AT THIS LINK
https://www.briggsandstratton.com/na/en_us/support/results.html?searchrequested=40504X92
Sep 16, 2013 | Murray Garden
I lost my instruction mamnual. What order do I
like this:
http://a.img-dpreview.com/reviews/FujifilmS5000/images/battcompartment.jpg
May 17, 2010 | Fuji FinePix S5000 Digital Camera
NetGear WGR826V has no clear port forwarding section in the setup, the mamnual is as clear as brick as to forwarding...so how do I forward a port on this brain dead router?
Forwarding Port – If you select 'Same as Incoming port' then all incoming traffic on specified Service is forwarded to LAN server without modifying Destination Port. – If you select 'Forward to another port range' then all incoming traffic received on the Service port (or range of ports) is forwarded to this port or range of ports of the LAN Server. – This field is disabled if action selected is "Block Always". – If you want to forward the traffic to a single port then enter port value in start port and leave finish port empty. – If you want to forward the traffic to range of ports then enter non zero value in finish port and make sure that service record attached to this rule has range of ports and range is equal to that of forwarding ports. – For example if you select Service as HTTP (TCP/80), LAN Server IP address as 192.168.15.10 and Forwarding port as 8080 then all traffic coming from internet on – TCP/80 (HTTP) to this Router is redirected to TCP/8080 port of 192.168.15.10 • WAN Users: These settings determine which packets are covered by the firewall rule, based on their source (WAN) IP address. Select the desired option: – Any All IP addresses are covered by this firewall rule. – Address range If this option is selected, you must enter the "Start" and "Finish" fields. – Single address Enter the required address in the "Start" fields. • Log: This determines whether packets covered by this firewall rule are logged. Select the desired action. – Never - never log traffic considered by this firewall rule, whether it matches or not. – Match - Log traffic only it matches this firewall rule. (The action is determined by this firewall rule.)
Ok well this is out of the manual, to me it seems straight forwards, but it is a brick too though, there is an example to help you, basically you tell it the Address of the PC, (Right click on NIC and get address) that you want ports to go to.. then ALLOW it, UN-disable actually.. in the tables.
Feb 05, 2010 | NetGear WGR826V Router (wgr826vna)
I need a mamnual for a dewalt dw567 type 1
dewaltservicenet.com
enter model in "find it now", click on the spyglass
click on type,
left side navigation should give option for both parts breakdowns and instruction manuals
Dec 12, 2009 | Dewalt Hammering
Exact Location of fuel pump relay 1989 Buick Century
Go to a repository library, which usually has the factory service manuals. Those will show you where the relays are and how to troubleshoot.
Jan 24, 2009 | 1995 Buick LeSabre
Can you direct me to a place or online site where I can get an operation mamnual For a SHARP CAROUSEL Model R930AW S/N 01562 Year 1997
here's the link to download via Sharp in pdf format...
http://www.sharpusa.com/products/TypeManuals/0,1083,5,00.html
Once there, scroll down a bit and you'll seee the download link for the R930 CS/AK/AW series
Aug 23, 2008 | Sharp Microwave Ovens
Have philips wireless modem from talktalk but dont have installation disc. need to install mamnually
I think this is a wireless router, and therefore does not need an installation disk.
all you need to do is connect to the router (using a lan cable if you cannot connect to it wirelessly) the default IP address should be 192.168.2.1 type this ip into IE you should get a configuration page and then you should then be able to configure the rest of the settings yourself
see info below
http://www.talktalk.co.uk/talktalk/servlet/gben-server-AssetServer?article=MAIN.UK.TALKTALK.STATIC.HELP.MODEMTYPE&asset=PDF1
Apr 10, 2008 | Computers & Internet
Xact Communication XTR1 SIRIUS Radio Receiver Logo
Top Xact Communication Audio Players & Recorders Experts
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
