Question about Alphasonik Car Audio & Video
Was intending to purchase,3,psw812j.whats the best size ported box(x3) an do i use one 4
Another thing they r refurbs,at 220 a set,was wondering,if these r good speakers?i intend to wire all [email protected] apiece,then in paralelle,with an 2400 watt,hifonics brutus mono amp,they will recieve bout,725,apiece. my ? is i looked up the manual,it said 2.5 cubic,ft,an needs to b 2.1 on the inside.says a2x2x4 port 11" long,is that one 4"port or two 4"ports?
Posted by audio enthusiast on
3 Related Answers
etirbynnor
Ronny Brite
  • 655 Answers
SOURCE: Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
Posted on Sep 08, 2009
Fred Yearian
  • 5603 Answers
SOURCE: I have a 12 inch ORION HCCA dvc, 4ohm sub. My
Halving the impedance will draw twice the current. You could technically get a 3 Db more power since the peak voltage will remain the same. BUT if the magnet structure is not intended to use that cone design, the magnet difference MAY not give you 2 ohms.
In fact, if the designed magnetic flux were smaller, you could wind up with a 1 ohm speaker.
trying to get that much power is really kind of silly as even 50 watts with efficient speakers will exceed safe levels of sound that will not cause damage to your ears.
As you push an amp up in power, usually distortion will increase as well.
Posted on Oct 26, 2009
Greg McCarthy
  • 1340 Answers
SOURCE: i have 2 kicker l7
Definitely a 4 ohm load.If you do 1 ohm,that will send 4 times the current to the sub and you may end up hearing $150 blow out.2 ohm uses twice the power as 4 ohm and is still alot considering the power formula.watts=amps x voltage however amps are determined by voltage divided by resistance. 12 v divided 4 ohms is only 3 amps. 12v
divided by a 1 ohm = 12 amps when you go to crank up the power by turning up the volume,that results in even less ohms and more power.lol.Just use 4.Good luck! Greg
Posted on Aug 30, 2010
Kawasaki Rouser 220 timing chain
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Kawasaki Rouser 220 timing chain Google Search
Bajaj Pulsar Timing Chain Replacement
Rouser 200 220 Service Manual
OEM Parts for Kawasaki
http://mybikemanuals.com/kawasaki
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 07, 2013 | kawasaki Motorcycles
We recently purchased the MS350 radios and are trying to use them handfree with the headsets. We plugged in the headsets, turned on the radios, but are unable to communicated back and forth using the VOX...
The three things which come to mind are:
1) Is the headset the VOX headset intended for the radio model? Sometimes the rings on the plug do not match the internal points of contact if it is not the intended headset. Not all headsets are VOX capable.
2) Is the headset plugged in all the way. (You mentioned plugging in and then turning on. This is good. You must always have the radio turned off when plugging or unplugging an audio device.)
3) Try pressing the PTT on the headset cord one time before switching the dip switch to VOX. (Assuming you have a headset with the small box in the line.)
Check your VOX/ iVOX settings. You will need VOX for using an audio device.
Lastly, if you continue to have difficulties, contact Motorola at the 800# provided in the user guide. They should be able to assist you.
Best regards.
Sep 23, 2013 | Motorola Hands-free Headset,for 2-Way...
Can we wire with 220 single phase
It should be all set for 220 volts, a 3 phase timer would be twice that size if they make one. Little things don't run on 3 phase power. Are you just running the lights with it? If so, you don't even need the 220, just one side of it will do, make sure you have a wire to the clock motor, should already be there, check it out, Hope this helps.
Aug 28, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Low virtual memory
Ok let me help you, hopefully you have atleast 2GB of hard drive space left.
Step 1: Double-click Control Panel
Step 2: Double-click System
Step 3: Click on the advanced Tab
Step 4: Click the "Settings" button under Performance
Step 5: Under Performance options Click on the Advanced Tab
Step 6: Click "Change" under Virtual Memory
Step 7: Select Custom Size, ( if custome size is grayed out uncheck Automaticall manage paging...)
Step 8: Change Custom Size to 2048, if you have more than 3 Gigabytes on your harddrive available, change the custom size to 3072.
Step 9: Hit the "Set" button then "ok"
You may need to restart your computer after this is complete.
This is really just a temporary fix. I would suggest purchasing more Ram for your computer. If you would like you may reply to this message with the make and model of your computer and I will gladly look up what you need to upgrade.
Feb 08, 2010 | Microsoft Windows XP Home Edition
I have 2 12 inch kickers and have a solid box in my mustang. would it sound better if it was ported?
Kicker speakers always require very large boxes (you're looking at 12 cubic feet for both), when ported. Ported boxes are very sensitive to box size, port tuning etc, so it's probably best to leave it sealed, as they are far more leniant, and sealed boxes are usually 1/2 size of ported boxes. You would get less bass when ported than with sealed (because ported boxes must be bigger to match the sealed ones).
If you wish to experiment with the bass response of speakers, download winISD, and put your speakers in, see what size boxes give you what.
Jan 09, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I have 2 1300w Sony Xpod 12'' speakers and want to make a box and get the best thump, or quality. help plz
the box is not hard to make its what you make it from and how you port the box for sound the port are use as a tuner the bigger the port dont make it sound good , for the best sound make your box with the subs faceing inside the box get you some 2in pvc pipe to use for your port cut 4 holes in the top off the box infront off the speakers cut your pipe about 3 in short from the bottom of the box , make the box 16"X16"X4' you need to make a bridge between the speakers you will cut 5 pec 4X16 then 2 pec 16x16 use glue and scews
HAVE FUN
Aug 16, 2009 | Car Audio & Video
Size of boxes
Wow you are in luck, I used to be an Audiobahn dealer. Designing sub enclosures is my fulltime job. So here you go.-
If you are looking for sound that is very smooth, and has a very low end shaking everything setting off car alarms. You will need a PORTED BOX that is 3 CUBIC FEET FOR EACH SUB WOOFER. It actually calls for 2.7cu.ft but after you add speaker displacement and bracing it should be at least 3 cu.ft. The port can be either round or square made of plastic or 3/4" wood respectively. My port suggestions are dependent on how much space you have. The shortest round port might make some noise (too much pressure!). So think about that first. Anyway the short port is 3" diameter and 15.5" long. The longer port is 4" in diameter and 28.25" long. The rectangular wood port can also be either (port measurements are inside diamensions) 3" w x 3" w x 18.5" long (short port) or 2 w x 10.5 h x 48' long. The second longer wood port is recommended most but will take up a lot of space. The fact that you have to subtract the port volume from the box makes for space issues in cars. Also the second wood port sounds better and won't make much wind noise, but takes up .75 cu.ft worth of space. So in plain english your box will have to have an internal volume of 3.75cu.ft. An example of this could be made of 3/4" thick MDF, have 1" x 1" internal bracing and measure (box dimensions are external and assumes the use of 3/4" MDF) 12" h x 18" w x 30" deep. The port is an integral part of the box fitting inside. I'm sorry I can't provide any drawings to make things easier. Now this box size is one that I ran through a computer program I use. So it is not the same as the manufactures recommendations. I will list those as well.
The second box is an example using a round short port and also uses 3/4" MDF, 1 x 1" bracing, the 3" dia x 15.5" long port, and measures 12" x 18" x 24" externally.
If space is an issue try checking out the information below. -I got it from Audiobahn-
If for some reason it doesn't show up or you need assistance let me know. Good luck and enjoy your new setup-I'm sure you'll be happily disturbing the peace soon!
-Dynami
Model # AW1006T
Ported
Air Space (Cu. Ft.) 0.65
Port Size (Inches) 2 x 6.5
Port Vel. (%) 48.31
-3dB (Hz) 31.5
Tune Freq. (Hz) 40
Sub Disp. (Cu. Ft.) 0.21
Port Disp.(Cu. Ft.) 0.01
Total Vol. (Cu. Ft.) 0.75
Ported
Air Space (Cu. Ft.) 1.4
Port Size (Inches) 3 x 6.75
Port Vel. (%) 24.19
-3dB (Hz) 30
Tune Freq. (Hz) 39
Port Disp.(Cu. Ft.) 0.024
Total Vol. (Cu. Ft.) 1.5
Ported
Air Space (Cu. Ft.) 2.4
Port Size (Inches) 4 x 6.25
Port Vel. (%) 14.39
-3dB (Hz) 29
Tune Freq. (Hz) 39
Port Disp.(Cu. Ft.) 0.04
Total Vol. (Cu. Ft.) 2.5
EBP 74 80 80
Sealed NR NR NR
Minimum (Cu. Ft.) 0.5
Maximum (Cu. Ft.) 1
SPL (dB) 80
All sealed boxes already include the displacment for the subwoofer. NR = (Not Recommended)
Mar 08, 2009 | AudioBahn AW1006T Car Subwoofer
Matrox Mystique 220 Graphic Card no display
I chatted with a Matrox guy, and confirmed my suspicion - your card is dead. Your best bet is to simply replace with an inexpensive card (BFG makes some nice Nvidia-based cards), and stick with new product, rather than refurbed.
Cheers
Nov 05, 2008 | Matrox Mystique 220 Graphic Card
PS3 60gb Warranty (discontinued)
They will substitute with an equal value ps3 or order a refurb and trade ya! IF YOU have any broken ones let me know ill buy em!
May 30, 2008 | Sony Playstation 3 (PS3) Console
Peugeot 106
you could use existing speaker wire from original speakers.and or just run new wire thru plastic kick panels , thru plastic base boards theh thru plastic rear kick panel ,thru rear seat ...
Dec 08, 2007 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
Car Audio & Video Logo
Top Alphasonik Car Audio & Video Experts
Marvin
Marvin
Are you an Alphasonik Car Audio and Video Expert? Answer questions, earn points and help others
