Cooked with oven screen is flashing f 2
Hi Nancy:
Error Code F2 indicates
a loose or broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced.
Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Hope this helps; thank you for using Fixya. Keep in mind that your feedback is important, leave us some testimonial comment.
