SOURCE: Configuring Belkin Wireless Router
You choose a wireless router so you need to install in some freequency. You can choose the freequency by the list like 2.4 G.Hz ect. then just select the link & fix threre working ares / type. Avoid the command prompt. use bessic settings your user manuel help you further.
SOURCE: Lost Belkin Wireless G Router F5D7230-4
Are you trying to install the router.
You can do it manually without the CD.
MAke sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
SOURCE: belkin n150 F6D4230 wireless router. lose ability to
try to upgrade the firmware of the router. that will help you.
For this you will need to connect the computer to the router. Do not upgrade the firmware of the router using the wireless computer.
You will need to download the new firmware from the manufacturer's web site. Then open the router set up page and upgrade the firmware of the router.
Click here for more information about routers and network
SOURCE: how to install belkin N150 wireless router
Follow the user Manual. It should be an easy setup.
Thanks
https://www2.belkin.com/support/article/?lid=en&pid=F5D5231-4&aid=5106&scid=220
SOURCE: F5D7634 Belkin Router how do I disable wireless op...
1. log into the router and click the "wireless" and uncheck the radio brocast.
