Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
when you start the cycle the water will disperse. but check the fillters at the bottom of the dishwasher and make sure the drain pipe end is not crushed if you are enptying into the kitchen sink drain make sure the pipe is not kinked back on its self. try and get it as strait as you can.
you are probably plumbed in under the sink for the drain hose. a common problem is water coming back down the drain hose when you empty the sink. if so take the drain hose up as far as possible in a swan neck. other possibility is a leaking fill valve
