Dell A920 InkJet Printer Logo
Question about Dell A920 InkJet Printer
Windows 7 Printer Error 0X00000006
Won't print
Posted by steve on
5 Related Answers
Anonymous
  • 236 Answers
SOURCE: Printer error
It sounds like a driver problem.. Try re-installing all the drivers.
If that doesn't work.. Are you running windows Vista? May be a compatibility issue..
Posted on Mar 26, 2008
Sanath Kumar V
  • 684 Answers
SOURCE: Printer will fax out, Will not copy
In this case go ahead and Uninstall the software from the Computer...... Download the following Link: http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0 Just go to this Link and select ur Product..... Download the drivers from here and install the Printer..... Thanku
Posted on Feb 05, 2009
gggg
  • 904 Answers
SOURCE: dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
Posted on May 28, 2010
Anonymous
SOURCE: HP Color Laser Jet printer CM1312nfi: scanner no
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Posted on Oct 17, 2010
Joed911
JDTec
  • 4338 Answers
SOURCE: My canon MX340 won't print,
Error 5200:
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jul 11, 2011
AGPTEK sc9-5870 thermal printer won't print
I got mine to work by changing the port from USB001 to USB002 prints great now, there is problems with installing on windows 8, you have to disable driver verification or the driver won't install.
Good printer don't give up on it.
3helpful
Windows Live Mail won't print on Windows 7 64bit
Try to check if your printer is set to Default.
Go to Control Panel > Devices and Printers> Under Printers and Faxes, locate your Printer name then Right click> Set as default printer.
Then try to print again.
Hope this helps.
Regards,
Charvin
Printer won't work with HP WIndows 7
I regret to inform you that the Lexmark X75 does not support Windows 7. It works on Windows XP and previous versions.
You may contact Lexmark Technical Support Center to check for other options.
How do I get A920 All-in-One to connect?
Hi Doris,
Please make sure the Operating System you are using corresponds with the printer driver.In other words,make sure the driver you're installing is compatible with the Operating System on your PC.
Check out your Operating System's compatible drivers for downloads from this Dell support site.
Make sure you unlock the scanner bed by pushing the scanner lock down.
Check the USB cable connections and make sure its secure.
If problem persists,return the product if still on warrant.
Hope this helps.Thanks!
My lexmark x1290 printer will not print firstly it said it was the spooler stopping it i fixed that however now it is saying that error 0x00000006 i stopping it from text printing i am running windows...
This looks like either you do not have correct drivers, or that the drivers didn't install or didn't install properly Double check that you have the proper drivers. If you do, try reinstalling them.
2answers
I am using quickbooks 2005 and am trying to print full page checks. I am getting a 'paper mismatch' error and cannot print my checks.
Welcome to FixYa.
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error.
How do you load your check in the printer?
Keep me posted.
Jas247
2helpful
Error
what operating system are you using?
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· Disconnect your USB cable from your printer.
· Uninstall all Lexmark printer drivers on your PC.
· Download the correct Vista driver for your model.
· Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
5helpful
2answers
Cannot complete operation error 0x00000006 what mean?
1helpful
Printer error
Top Dell Office Equipment & Supplies Experts
Marvin
Marvin
Jaime Hernandez
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
